Old 11-28-2007, 09:49 PM
fredmc is on a distinguished road
Default Pin Holes
I am doing a test of Columbia Super Clear Coat on polished aluminum.
I polished a piece of thick aluminum and cleaned it with Prep &Clean. I then shot a coat of powder on it, baked it at 375 for 15 minutes(according to directions). The finish is full of pinholes.
So I applied another, heavier coat of powder and baked it again for 15 minutes and its still the same, if not worse.
I am using a HF gun.
What usually causes this?
Thanks
Fred
Fred Mc.
Old 11-28-2007, 11:24 PM
baz baz is offline
baz will become famous soon enough
Default Re: Pin Holes
Thanks
Fred
Fred Mc.
could be from outgasing , or from water in your air line.
fix for outgasing problem: before you powder the part . put it in the oven for about 40 minutes at 25 to 50 degrees over the temp tht you will actually cure the part.
fix for water in air line is simply to get a good filtering system
baz
http://www.polissagepb.com
Old 11-29-2007, 07:13 AM
FigureLLC's Avatar
Caswell Platinum Member
FigureLLC is on a distinguished road
1) do you know how the piece of aluminum was formed? outgassing is common with cast parts. tiny air bubbles are formed in the aluminum during the casting process, and when the metal is heated, the metal's pores open up and allow some of the gas to escape, creating pin holes while the powder is curing. solution: outgas prior to shooting per baz's instructions.
2) i'm not sure what the "prep and clean" stuff is, but i think most people use acetone for cleaning because it leaves no residue. some cleaners are either petroleum-based or have some type of corrosion inhibitor, etc. that can mess up powder cure. solution: use acetone to clean.
3) this really should be no. 1... like baz said, clean/dry air will increase finish (and spraying -> reduced clumping) consistency. solution: drain air compressor tank daily (or better yet install an automatic drain, like the $12 one from HF), and in the air line close to point of use install a coalescing filter (removes heavy moisture/oil/particles) followed by dessicant filter (dries air) followed by a regulator/particulate filter (catches the dessicant particles).
Len
Figure Engineering, LLC
Old 12-02-2007, 12:34 PM
The Prep&Clean stuff is the cleaner recommended by Columbia Coating.
Old 12-03-2007, 12:43 PM
FigureLLC's Avatar
oh, it's probably not that, then. when you cleaned it, did you shoot the spray on it and let it evaporate, or shoot it on and wipe it off? works best to wipe, otherwise oil is disolved into the solvent, the solvent evaporates, then the oil is still on the part.
Len
Old 12-03-2007, 08:05 PM
Harleydad's Avatar
Here's a trouble shooting guide for future reference.
http://www.tiger-coatings.com/filead...guide2_usa.pdf
Old 12-04-2007, 05:21 PM
FigureLLC's Avatar
outstanding. thanks!
Len
PCing a part with no holes cruizer Powder Coating Questions 9 08-26-2005 08:44 AM
plugging holes and methods buzzurd Powder Coating Questions 1 12-26-2004 07:48 PM
What is the best way to mask threads and holes? krsimulis Electroplating Questions 2 06-03-2004 11:18 PM
Plugging holes prior to plating. chcarver Electroplating Questions 2 05-01-2003 11:10 AM
pin holes harold Other Metal Finishing Questions 1 08-25-2002 08:53 PM
