Old 12-06-2007, 08:48 AM
FigureLLC's Avatar
Caswell Platinum Member
Default powder base, wet paint detail, clear powder
i'm shooting a bicycle frame and i would like to shoot a powder base coat, mask and wet paint some lettering/detailing, and then powder coat it. i know it's possible (see video below), i'm just not sure what paint to use, or if any automotive paint will work.
check out the first video here: http://www.spectrumpowderworks.com/spwmovies.php
Len
Figure Engineering, LLC
Old 12-06-2007, 10:43 AM
RNMHRD's Avatar
RNMHRD is on a distinguished road
Default Re: powder base, wet paint detail, clear powder
candy base coat in powder and the detail done with an air brush and liquid clear.
Thats how it says they did it.. Sio they used a liquid clear not Powder..
Old 12-06-2007, 11:17 AM
FigureLLC's Avatar
the third video is wet clear, i referrenced the first. the first video goes
1) powder base coat
2) partial cure of base coat
3) mask and airbrush detail work
4) powder clear top coat
5) full cure
fast forward to 11:30 of the first video where it shows them shooting the clear.
Len
Old 12-10-2007, 12:00 AM
FigureLLC's Avatar
they offer this info, too. sounds like they guard this secret.
"Myth - You can't put detail finishes under a powder clear coat.
Fact - We have figured out a process to allow detail to be put on between base coat and clear coat. You cannot use normal paint(containing binders and flow agents), then apply a powder clear. The temperature will cause normal paints to change color and crack...etc. We use special pigments in a carrier that allows us to use an air brush, but with no binding agents. The result is something that is very fragile and easy to pull up. When a powder clear coat is applied, the base and clear cross link thru the pigments to make a single finish. It really looks cool to have airbrushed graphics and no edge, just a seamless show quality finish."
Len
Old 12-10-2007, 12:38 AM
CarWiz's Avatar
The urethane base auto paints can generally handle up to about 300 degrees because of the binders but the waterborne paints can go much higher. They should be able to handle the temps of a urethane powder coat. (They use the same solids.) If I were to try this, I'd look into the water based auto paints. Standox and Dupont are big into the waterborne paints. Europe has been using it for years.
Old 12-21-2007, 04:31 PM
FigureLLC's Avatar
i got it. pics to come.
Len
Old 12-22-2007, 12:39 AM
Blazin_Jason is an unknown quantity at this point
I want to see that. I wouldn't mind being able to airbrush from time to time. So what type of wet paint can be used for that?
Is it paint or is it powder??? Harleydad Powder Coating Questions 4 12-18-2006 07:59 PM
Clear Powder Coat over Paint???? chcustom Powder Coating Questions 2 12-03-2006 02:08 PM
powder paint temp dlaery Powder Coating Questions 0 10-19-2006 12:06 PM
PPG paint # matched to powder? trsick Powder Coating Questions 6 04-01-2005 04:49 PM
Can you use any powder paint with your Toma Powder Coating Questions 1 01-04-2002 12:53 PM
