FREE POWDER COATING SYSTEM
for a powder coat gun,whats a decent size air tank? i have a 25 gallon with like a 4 hp motor, its a craftsman but VERY old and would like to get a new one. i would be using it for other air tools also.. what size hose do i need? not in length, in thickness or diameter.. and what is a good filter to get moisture out. what is a good website to purchase all of this stuff? thanks
well i wont be getting a caswell gun, so where could i pick up a filter? does it have to go right before the gun or can i put it like in the middle of the line?
my tank is VERY old and leaks a bit ( i paid 60 bucks for it.) im thinking about picking this up.. http://www.sears.com/shc/s/p_10153_1...air+compressor and comments on it? |
put the filter as close to the gun as possible. when air is compressed water enters the lines in a vapor form. it will only condense to liquid form as it hits coldness, so the further from the compressor the water trap/separator is installed the more efficient a job it will perform.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
yeah, that compressor will serve you well. two things you may want to consider with that particular compressor (we began with that one):
1) harbor freight sells an "auto drain" that you can plumb into the bottom of the compressor. they are triggered every time the compressor cycles on and then again when it shuts off, and it's activated automatically by pilot pressure from the blow off valve. they are $12 and worth every penny. NOTE: do not overtorque these as they're a bit fragile. 2) this is for any compressor... rubber hose retains heat, so water vapor won't condense in the air lines as quickly (bad). if you are able to run metal pipe (preferably galvanized) to a couple places in the shop, this will help water vapor condense out. also, run the pipe as high as you can to assist condensation/gravity. the next step would be a coalescing filter to remove condensed water. this isn't necessary initially, but maybe something to consider down the line.
Len Figure Engineering, LLC |
no i just got to decide if i should make my booth from wood or pvc and painters tarp. both would be good but the wood would be alot more expensive. what do you think? and also, what kind of dust collector or ventalation system am i going to need? like i said, im new to this stuff, been reading a bit tho and from waht i see some ppl use shop vacs with a filter in front of the hose, do you run the shop vac all the time when your spraying? what about just an exhaust fan?
| air compressor | JeffL | Powder Coating Questions | 3 | 03-14-2006 03:26 PM |
| Compressor help | mpierich | Metal Polishing Questions | 2 | 07-13-2005 10:29 AM |
| Air compressor questions | Jay87T | Powder Coating Questions | 1 | 02-25-2005 11:47 PM |
| Compressor Piping questions | Noob2PC | Powder Coating Questions | 11 | 02-08-2005 07:07 AM |
| Air compressor | meanis | Powder Coating Questions | 1 | 05-13-2003 10:51 PM |
