FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 12-27-2007, 11:00 AM
krisnet55 is on a distinguished road
Default How do I connecta regular home gas oven to a propane tank? Please Help!!!
I am going crazy and want to do this in the safest way possible. Electric is impossible for me because I am currently renting a garage where I park my car and have basically turned it into to a shop as it is, so Im sure the landlord wont let me convert the electricity to 240v. So heres what im trying to do, I have a regular home oven that is set up for natural gas, I have read the instructions and regulated the valves for propane. But I still have a problem and a worry, I cant seem to find a hose that will fit from the propane tank to the oven. My worry is that Natural gas has less pressure then a propane tank so therefor I think I need some sort of regulator (im not sure) even though I adjusted the oven to run propane. Does anyone know what exactly I need to do to set this up properly and where to buy what ever I need. I dont want to end up powder my self. Thanks
Old 12-27-2007, 01:07 PM
Default Re: How do I connecta regular home gas oven to a propane tank? Please Help!!!
You need to go to an LP supplier and tell them what you want to do... they should have regulators and hoses to make the connection.
That being said, LP is nothing to screw with... and I would make sure your landlord and insurance company knows what you're doing
Old 01-01-2008, 10:04 AM
FigureLLC's Avatar
Caswell Platinum Member
to the best of my knowledge, most natural gas ovens are lp-compatible. there is probably a regulator before the safety valve where you will flip a plastic piece. then, down at the burner where the gas line goes into the burner venturi, there is an orifice with a hex collar. tighten that down. it will then work off of a bbq-type lp tank. buy one of the lp tank hoses with the regulator built into it (it automatically limits pressure). remove the natural gas hose from the back of the oven and add a coupling that is oven/lp line compatible. try mcmaster-carr if you can't find anything at a local hardware store. also note that the lp hoses for grills are not intended to be used indoors. i'm not saying we haven't...
Len
Figure Engineering, LLC
Old 01-04-2008, 12:36 PM
jbar800 is on a distinguished road
I agree that you need to contact the supplier. BUT, you also should contact the manufacturer of the oven. You need to ensure that if presently used for natural gas you know what is needed to convert for LP.
I used to be in appliance repair and I can tell you that in many appliances the orfice needed to change. The natural gas orfice is much larger and sends out much more gas than what LP requires. I wouldn't think of trying it without first contacting someone that would know for sure (manufacturer).
Old 01-04-2008, 07:43 PM
FigureLLC's Avatar
i know the old oven we used had a name plate under the stove top panel that said natty or lp. with a little online research i found out i had to 1) flip a plastic plug in the regulator, and 2) screw the orifice down tight. i originally only flipped the regulator plug and the flame was orange and all kinds of dirty. screwing the orifice down (almost) tight brought it back to a nice blue clean flame. i had the same difficulty finding an adapter to let me use a propane connection. when we built the oven we plumbed it from scratch so i just used the fittings i needed instead of an adapter.
Len
Old 01-05-2008, 01:34 AM
floppyspoppy is on a distinguished road
Unhappy Re: How do I connecta regular home gas oven to a propane tank? Please Help!!!
First you will have to change the "orfice" in the gas valve. Then you will have to set the gas pressure. Natural gas needs about 3" inches of water colum whereas propane operates at about 10" inches of water colum. Probably the easiest thing for you to do is find a heating & air guy that does side jobs. It is complicated to the general public but a pro will know exactly what I am talking about. It is not a simple adjustment pressure wise you can make, you will have to change some internal parts in the gas valve and then check & adjust the pressure with a specialized pressure guage. Just about any h.v.a.c guy can do it, but he will probably have to get some parts , maybe even a new gas valve. You will definetly need the brand name of the oven + model & serial #'s of the oven and the gas valve too if possible. Please don't monkey with it too much it is very dangerous. Look for somebody in a heating & a/c van and grab their attention and talk to them, It won't cost you a dime for a minute of their time. Good luck and leave it to a pro..........
Could a home-brew Babington Waste Oil Burner be used to fire a PC Oven? BerkelUSA Oven Building Forum 14 01-16-2008 08:42 PM
Home oven questions snyiper Oven Building Forum 2 07-01-2007 12:54 AM
oven build/ elec IR/ or propane IR? Carcher7878 Oven Building Forum 8 04-06-2007 04:29 PM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 09:57 PM
Highest temp regular powder can take? wamontgomery Powder Coating Questions 2 07-22-2005 11:26 AM
