Old 12-28-2007, 02:51 PM
mxracer43 is on a distinguished road
Default 2nd Coats Candy
Does anybody have any tips on getting a good coat with candies or other 2nd coats. I am using a standard and selectable voltage gun rfom caswell and extreme chrome base. I am having problems getting the powder to attract on the 2nd coats. I have tried new grounds and have had only little better sucess. Please let me know if you all have some helpful info. My 1st coats always go on perfect. Thanks...Brian
Old 12-28-2007, 03:25 PM
holeshot87
Smile Re: 2nd Coats Candy
i alway shoot the 2nd coat hot around 120 to 150. this seem to work for me. maybe there is a easier way to shoot it but this is the way i do it. dont put it on to thick or it will run. hope this helps.
Old 12-29-2007, 02:37 AM
yzviper is on a distinguished road
Default Re: 2nd Coats Candy
I always shoot my candies at @200. Works out great, just watch your thickness. Hot flocking can build up on you quick.
Old 12-29-2007, 09:09 AM
jw450r1 is on a distinguished road
Try shooting your first coat a little lighter.still cover the part but it's only the base coat.then shoot ou second coat.thats what i found worked better for me
Old 12-29-2007, 12:16 PM
nuttyman's Avatar
nuttyman
hot flocking is a lousy way to shoot!
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 12-29-2007, 11:35 PM
Candies are the only colors i shoot @200. I just can't seem to get them to come out looking right if I don't. Haven't figured out what i'm doing wrong yet. Any suggestions?
Old 12-30-2007, 12:20 AM
nuttyman's Avatar
nuttyman
I try not to hot flock anything. when I shoot 2nd, or subsequent coats I always ensure a clean ground & turn the voltage down to 30 & full current on my gun. you really have to pay close attention to how much you are spraying because with candies they tend to build up on the edges & run if they are not sprayed uniformly.
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
  #8 (permalink)
Old 12-30-2007, 12:39 AM
Thanks for the advice. I got the idea from reading other posts on here from much more experienced coaters than myself. The first time I tried it, the part came out so much better than previous attempts without heat. It just seems to be a much easier way to do it. Is there any structural disadvantage to doing it hot?
  #9 (permalink)
Old 12-30-2007, 04:04 PM
nuttyman's Avatar
nuttyman
no there isn't.
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
  #10 (permalink)
Old 01-02-2008, 12:48 AM
Thanks for some tips. I shot some stuff today and it is just not getting good adhesion. I have tried extreme chrome, near chrome and a silver metallic. I am shooting a freshly coated part so it isn't dirty, but I still have problems. Part might be the candy, but I am sure you all are having success. I don't really know what else to do. Should you clean the part before puttin on the 2nd coat?
Nutty, could it be the fact that i don't have a real expensive gun, I have ground off clean points for contact.
I had real bad results with the near chrome and extreme was better, but this batch of extreme i bought is just as bad as the near was.
An idea for second coats. mtumbleson Powder Coating Questions 7 05-30-2007 06:20 PM
suggestions for two coats? FiReBReTHa Powder Coating Questions 6 05-28-2007 10:55 PM
Problem with two coats sportster883r Powder Coating Questions 1 10-04-2004 05:45 PM
when doing multiple PC coats..... strongtower Powder Coating Questions 4 05-21-2004 01:44 PM
clear coats!!! hue Metal Polishing Questions 7 05-09-2003 12:28 AM
