Old 12-30-2007, 11:03 AM
Platinum Member
Caswell Platinum Member
Landest is on a distinguished road
Default Brushless fans for paint booth
Has anybody used brushless fans for a paintbooth?
Example: http://www.buyextras.com/acfans.html
Old 12-30-2007, 07:21 PM
nuttyman's Avatar
nuttyman
Default Re: Brushless fans for paint booth
those are meant for cooling electronics. you would probably have to use quite a few of them to effectively filter your booth.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 12-31-2007, 10:02 AM
Platinum Member
True, they are used for electronics in many applications... but they have no motor brush and therefore no brush spark.
I guess I am trying to engineer my way around the spark in the paint booth (.. potential explosion, aka fire safety code") thing. I have run across several readings on this subject and therefore assume it is something that I need to consider.
I looks like the folks on this forum have some great ideas. If a straight forward "industry standard" solution exists, please point me in that direction.
Thanks
Old 12-31-2007, 11:35 AM
nuttyman's Avatar
nuttyman
you can use cheap fans that have a spark just make sure your filtering effectively filters the powder. use 2 or more types of filtering material, make it 2 or 3 stage. start coarse.
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 12-31-2007, 01:38 PM
99% of the time the motor is not in the air stream. A tube-axial style fan with an aluminum prop is standard fare. You also need good filtration to keep things clean and efficient.
Old 12-31-2007, 04:10 PM
Platinum Member
Don't fix the fan.... remove the dust before it gets there.. Got it
Thanks
Old 12-31-2007, 06:42 PM
nuttyman's Avatar
nuttyman
Thanks
exackree!!!
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
  #8 (permalink)
Old 01-02-2008, 02:51 PM
Sorry, for some reason I thought you were talking about liquid paint.. Duh..
Recirculation fans... KZjim Oven Building Forum 2 04-19-2006 08:07 PM
My new booth... DriKote Powder Coating Questions 8 04-05-2006 02:37 PM
exhaust CFM for paint booth? AAPowderCoating Powder Coating Questions 1 01-23-2006 03:26 PM
No Booth, Can I still PC? Daytony Powder Coating Questions 3 05-24-2004 07:18 PM
booth? csaddler Powder Coating Questions 1 01-24-2004 06:31 PM
