  #11 (permalink)
Old 01-11-2008, 06:59 AM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Two color powder coat
Originally Posted by Harleydad View Post
If I understand this right you're going to apply the masking to a partially cured clear?
that's what i would try. no good? i've admittedly never masked over clear, but other colors i haven't experienced problems with. the only difference i've noticed about partial cures is they chip when abused. regular handling, masking, cleaning, i haven't seen a difference. i do see a difference in the finished adhesion (in the form of chipping under special conditions) when applying a top coat over a fully cured base coat when i smack it repeatedly with a hammer.
edit: if i'm wrong it wouldn't be the first thing i learned in this thread!
Len
Figure Engineering, LLC
  #12 (permalink)
Old 01-11-2008, 08:33 AM
Harleydad's Avatar
I'm not saying it's right or wrong, I guess I've never heard of applying masking to partially cured powder. It would scare me a bit. I suppose it would depend on what partially cured is. Like PCT said, be sure the flow stage is complete?
Powder Coat Primer with Wet Paint Top Coat? FigureLLC Powder Coating Questions 10 07-02-2008 09:25 AM
did mah first two coat, two color FiReBReTHa Powder Coating Questions 6 06-13-2007 10:43 PM
2 Color Powder Coat?? donafams Powder Coating Questions 3 04-27-2007 10:54 AM
powder coat color mapexlb Powder Coating Questions 0 06-25-2006 01:38 AM
powder color pickleboy Powder Coating Questions 1 07-13-2005 01:41 AM
