FREE POWDER COATING SYSTEM
no-just remove it as soon as the 2nd coat flows then put back in the oven & fully cure.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
that's what Isaid. the tape won't stick to the black if removed when the chrome flows. chrome powders always look better over gloss black bases. they just do.
Thanks for all the advice! I'm working on a 56 Ford instrument cluster and would want to keep the semi gloss black to roughly match the rest of the dash. The rest will be painted. So it sound like I should do the whole thing chrome first, clear it (I can probably avoid the upper surface during the clear process) Mask it and then semi gloss the rest. It's sure worth a try! Thanks again. Chuck in NH
PS, anyone out there near Manchester, NH with a larger oven? |
next time you do a chrome shoot a gloss black base & give it about a 1/2 cure. it works well that way.
I would theorize...that IF you're not very careful about making sure that the flow stage is completely finished (with the clear coat) that the masking may leave an imprint on it when you put it back in the oven for the black to flow. I've been told that the best way to ensure adhesion between layers is to only partially cure the first layer and then leave the part bake until fully cured for the second (or final) layer. I've never really tested this theory, but it would seem to make for dangerous handling before the second spraying. What is the reasoning for only partial cure with the clear coat?
| Powder Coat Primer with Wet Paint Top Coat? | FigureLLC | Powder Coating Questions | 10 | 07-02-2008 08:25 AM |
| did mah first two coat, two color | FiReBReTHa | Powder Coating Questions | 6 | 06-13-2007 09:43 PM |
| 2 Color Powder Coat?? | donafams | Powder Coating Questions | 3 | 04-27-2007 09:54 AM |
| powder coat color | mapexlb | Powder Coating Questions | 0 | 06-25-2006 12:38 AM |
| powder color | pickleboy | Powder Coating Questions | 1 | 07-13-2005 12:41 AM |
