FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 01-14-2008, 06:17 AM
irelandmoss is on a distinguished road
Question double coat
Can you shoot one coat, cure it then shoot
another coat to get depth on the part?
Thanks for the help.
Old 01-14-2008, 07:47 AM
Harleydad's Avatar
Default Re: double coat
Yes you can but, what powders are you shooting?
Old 01-14-2008, 09:43 AM
Question Re: double coat
One example: gloss black over gloss black.
More to give the piece the depth look.
Not like you're looking at the paint but
into the paint
Old 01-14-2008, 09:53 AM
mikmj's Avatar
mikmj
into the paint
I dont think it would work over a solid color.........I would try a high gloss clear.
Mike
Old 01-14-2008, 01:14 PM
97Dually is on a distinguished road
And be sure to lightly sand with 220 grit if you`re allowing the parts to fully cool between coats
Old 01-14-2008, 02:43 PM
FigureLLC's Avatar
Caswell Platinum Member
don't fully cure the first coat, either. put it in until the powder flows out evenly, then remove it, shoot it, and fully cure. that way the second coat will cross link with (melt into) the first.
Len
Figure Engineering, LLC
Old 01-14-2008, 03:13 PM
PCT17522 is on a distinguished road
Lightly sand the gloss black coat before applying the clear coat? I know that's how people apply multiple coats of clear paint for the "depth" look, but I've never tried it with powder coating. I've noticed that fingerprints from excessive handling sometimes show through a clear coat and just assumed that scuffing would also...
  #8 (permalink)
Old 01-16-2008, 11:48 AM
FigureLLC's Avatar
if you don't fully cure the base coat, i don't think you'll need to scuff it. if you have any imperfections in the base coat, you can sand them out. i haven't ever been able to see scuff marks under a top coat.
Len
  #9 (permalink)
Old 01-16-2008, 12:52 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
you won t see scuff marks under the clear ,but if you doube coat right away after doing half cure on first coat no need to scuff i would not even touch the part , just blow with a air hose if you suspect any dust on part before recoat .
baz
http://www.polissagepb.com
  #10 (permalink)
Old 01-16-2008, 06:35 PM
LittleViper's Avatar
LittleViper is on a distinguished road
Every time I put clear over black it turns green
Also when I do dormant colors such as orange then coat over with a textured it also turns the black green
This cover was done with the dormant orange then I coated it with a texture.
Under the lights and the flash it looks great but the moment you put it in the sun light it looks like a green turd!
Can some one explain this?
Oh yea sorry to high jack this thread.
Powder Coat Primer with Wet Paint Top Coat? FigureLLC Powder Coating Questions 10 07-02-2008 08:25 AM
Anyone ever use a double oven? pcer Oven Building Forum 2 11-27-2007 05:23 PM
double nickel plate Cameratrick Electroplating Questions 5 02-08-2006 08:10 PM
