Old 01-16-2008, 08:04 PM
swpruett is on a distinguished road
Default Iron Phosphate vs. Phosphoric Acid?
Well......I've been searching through all the posts I can find on pretreatment with Iron Phosphate looking to educate myself on the product. I understand the principles involved in it's use, but I have thoroughly confused myself on another hand.
Specifically, I am having a hard time understanding the difference between common phosphoric acid used as a metal "prep" before painting and "iron phosphate" used in p.c. pretreatment. I'm no chemist, but it seems iron phosphate is the byproduct of the reaction that results from the application of phosphoric acid on ferrous metals (but I don't know).
The ultimate question I have is this: Is Iron Phosphate simply a phosphoric acid incognito? If so, can I use the commercially (and locally) available phosphoric acid and achieve the same results?
I appreciate any help you folks can provide.
Regards,
Sven
Old 01-16-2008, 10:54 PM
CarWiz's Avatar
Default Re: Iron Phosphate vs. Phosphoric Acid?
Iron phosphate is FePO4. Phosphoric acid is H3PO4. As a coating, they work differently. You can get IP by visiting a garden shop. It's sold as a slug killer. Look for Sluggo & Escar-Go brands. They are two that consist of Iron phosphate.
Old 01-17-2008, 08:40 PM
Thanks for the lesson. If I can't expect the same results between the two, then I am inclined to go ahead and buy some of the "industrial" product made for P.C. Kind of a pain as I was hoping I might have a local source at less cost. Never that lucky........
Regards,
Sven
Old 01-17-2008, 11:46 PM
jazzcornet is on a distinguished road
i would like to be more familiar with how it works. or more specifically, how do you use it. i have the iron phosphate primer, but im not sure how to use it or when to use it. can anyone give me a pointer or two? perhaps a simply chemistry lesson on how it works would be sufficient as well.
Old 01-19-2008, 06:11 PM
Harleydad's Avatar
How Iron phosphate works.
http://www.powder-coater.com/phosphating.htm
Old 01-19-2008, 06:16 PM
very helpful thanks!!!
Old 01-19-2008, 10:54 PM
The thing that worries me is flash rusting after the rinse. In my limited past experience with phosphating, most attempts to rinse after coating with phosphoric acid-based products result in flash rusting almost before your eyes. Is iron phosphate similar and does it leave the "powdery" residue that some phosphateting products do on steel?
Thanks!
Sven Pruett
  #8 (permalink)
Old 01-19-2008, 11:08 PM
i would also like to know how to apply the iron phosphate primer
  #9 (permalink)
Old 01-20-2008, 06:58 AM
Harleydad's Avatar
The stuff I use is mixed with water. There's more to it, but you really need to watch the ph, you want it around 4.0-4.5. Lower will give you flash rust. The white powdery residue is from too long a dwell time or too heavy a coating. Section 1.2 of Tigers trouble shooting guide lists a few problems and correction suggestions.
http://www.tiger-coatings.com/filead...guide2_usa.pdf
Iron Phosphate vs. Phosphoric Acid? swpruett Oven Building Forum 0 01-16-2008 07:55 PM
Iron Phosphate? Inferno Powder Coating Questions 2 02-25-2006 08:32 PM
Anyone use the Iron Phosphate Primer? engineerscott Powder Coating Questions 10 01-04-2006 12:13 PM
Need help with Iron Phosphate wash Pearl-Jam Powder Coating Questions 12 02-08-2005 07:00 AM
Dangers of using Phosphoric/Chromic Acid mix? 00_buckshot Anodizing Questions 7 01-13-2004 09:27 PM
