I have read a few threads that have said you can very lightly blast Chromex with glass beads to remove the initial DULL look and then polish? Will this work? More details as to the exact type of glass beads, gun pressure, technique
![]() Thanks for any help. |
it will not polish , it will look light silver and then will be harder to polish .
if you are polishing chromex you are better off using steel wool #000 and a polishing wheel with white compound. |
I could never achived a very high polish chrome look with the blasting method .
once blasted it's harder to loose the blasting profile with the wheel specialy in hard to reach areas |
That's where a small light weight wire wheel and a Dremel comes into play. Just as with anything else in our line of work, be careful and take a little time with the wheel.
I have a set of SBC Block huggers to do in about a week.
Who says you can't teach an ole dog new tricks? |
Just being curious, how much do you guys charge to polish? I have been just using steel wool and telling customers polishing will cost extra. Most leave it as is and like it. But some, are turned off.
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
JTW, what material/abrasive do you use to blast the ceramic coating with prior to polish?
I understand jtagger's point that perhaps I might be adding an extra step by blasting maybe I'd just be making more work for myself. I will try steel wool then polish...and see if I'm happy. Sounds like it might be easier. |
I use glass bead with air pressure set at 25-30 psi. Then I use my soft wire wheel or polishing compound and polishing wheel. Still experimenting.
I don't like the steel wool because it makes and leaves a mess.
| Cerekote Chromex | rowdenboyz | Oven Building Forum | 0 | 09-08-2007 07:21 PM |
| Chromex in the oven right now | JTW37 | Powder Coating Questions | 18 | 07-12-2007 01:05 AM |
| Unused Cerakote Chromex | m67bd70x | Used Items For Sale | 2 | 07-25-2006 09:03 PM |
| Chromex Help | m67bd70x | Powder Coating Questions | 9 | 12-31-2005 04:02 PM |
| sand blaster / bead blaster? | Chevalier | Anodizing Questions | 2 | 02-07-2004 03:15 PM |
