  #11 (permalink)
Old 02-01-2008, 12:14 PM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Marble effect?
best info i found said it's a thermoplastic base coat partially cured, with a thermoset top coat "selectively removed". sounds like there are different ways of removal including patterned screens or the faux finish paint technique of balled up seran wrap. something else that came up was dye sublimation. basically, you print a design or graphic on some type of transfer paper with a special ink, shoot the base coat, heat it a bit, apply the transfer paper, remove the paper, and the ink transfers into the gelled powder, then the part is cured. that's the extent of what i've got so far (mostly based on the thread harleydad linked... thanks! good info!).
Len
Figure Engineering, LLC
Fade effect - powder coat vertek Powder Coating Questions 21 10-08-2008 07:12 PM
Effect of a magnetic stir bar? dkbishop Electroplating Questions 1 02-06-2007 11:03 PM
PC toumbled marble tiles photomassage Powder Coating Questions 0 01-02-2007 12:17 PM
Picture framing effect? callmej75 Powder Coating Questions 8 03-28-2006 09:01 PM
Anodising, cooling effect? 50gary Anodizing Questions 2 01-09-2006 02:03 AM
