Well i'm ordering my first powdercoat setup.
What is the difference between the caswell gun and the hot coat gun? How much powder would i need to do a atv frame, subframe.. Can you tell me what color yellow is on these a arms? ![]() and what blue is this on the frame? ![]() thanks alot guys. |
im VERY VERY new to this, so my question is, how do you know if you have to put a certain base under the color? or if you have to put a clear on top. I do know that for candy colors you need to put chrome under it.
thanks espo |
Nope.
I use a resperator only if im haveing to work in the same room with the oven just so I don't have to smell it. it gives me a bad headache if I have to smell the fumes while working in there.
WARCHILD |
well the oven and the booth are both going to be in the garage. will the fumes travel into my house? I guess im going to need to get a good exhaust fan? any suggestions?
thanks espo |
It mite go in there if you garage is att to your house.
I would get an exhaust fan of some kind. My set up is in a little building and I just leave the door open in that room to let the fumes go out side. it's gets cold being winter time but I work better in the cold.
WARCHILD |
Read some of the old posts. Everything you need to know is here........ Mike |
| Couple questions | RobsPCing | Oven Building Forum | 0 | 02-16-2007 10:59 PM |
| New Kit Couple Questions Please | rockp2 | Electroplating Questions | 3 | 12-18-2006 06:42 PM |
| Couple Questions on PC | lsw11 | Powder Coating Questions | 6 | 11-01-2005 12:40 PM |
| Two quick questions | sportster883r | Powder Coating Questions | 8 | 10-05-2004 10:00 PM |
| New here, couple of quick ones (yes I read the manual! :-) | Stryder | Metal Polishing Questions | 22 | 12-15-2003 05:59 PM |
