Old 01-28-2008, 06:18 PM
pcer is on a distinguished road
Default Caswell Gun sprays out too much powder...
My caswell gun (standard) don't have a stickey trigger, but when you hit the trigger a BIG thick cloud comes out.......I have a pressure regulator and have tried from 1psi to 20 psi.......what setting do you use?? also is there anything else I can do to stop it? It is wasting alot of powder. That little adjustment knob seems to have no affect on it....what can I do?
Old 01-28-2008, 06:51 PM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Caswell Gun sprays out too much powder...
fill the cup up maybe 1/2 way. if it's too full, you'll get clouds.
also, when you remove the cup and look at the little nub sticking up (fluidizer), it has a hole in it. air flows through that hole to stir up (fluidize) the powder. drill 2 or three more holes of the same size in the nub. this will improve fluidization and reduce the puffs of heavy powder.
aslo shake the powder before shooting to loosen it up.
Len
Figure Engineering, LLC
Old 01-28-2008, 10:08 PM
wlovre is on a distinguished road
Check your regulated pressure on your line, and the max input pressure on your powder gun regulator. If you exceed max allowable input pressure, the regulator will just blow by and not give you regulated pressure. Had that happen once, was a devil to figure out what was going on until I stumbled across it.
Old 01-30-2008, 09:03 PM
thanks guys, cut the holes in the areator thing and fiddled with the pressure and its doing pretty good.
Old 01-30-2008, 10:37 PM
bahhh well it still wants to dump powder out when you point the end down
Old 01-31-2008, 08:29 AM
FigureLLC's Avatar
yeah, you'll learn what the gun likes and doesn't. just part of the overall learning process. after you use it a dozen times or so you should have a pretty good handle on it.
Len
got the Caswell gun now need advice on powder grommit Powder Coating Questions 6 09-27-2007 10:01 PM
xxx/Caswell Powder coating Gun ?? RNMHRD Powder Coating Questions 2 09-19-2007 07:19 PM
Caswell Powder Giveaway callmej75 Powder Coating Questions 2 01-01-2007 03:17 PM
Caswell Powder coating gun Woodfrag Used Items For Sale 0 07-04-2006 07:05 PM
1st job w/ Caswell powder nuttyman Powder Coating Questions 2 06-03-2004 06:42 PM
