When is clear coating necessary / desirable? I am going to be using some of the lollypop blue on some tins for a chopper (tank, fender, ect.) does this NEED to be clear coated or does that just give a higher gloss finish?
In addition I may be powder coating some rims that are chromed already, is it recommended to have them professionally de-chromed or is there an adequate process for this at home? P.S. this is a great forum I have been reading through lots of post's and learned lots from you guys already, Thanks! |
Lolloypop Blue does not require clear. I do not think it will give it any additional shine or depth. as far as powdercoating on chrome, I have done it many times and have awsome results. I will sometimes (depending on how much use the parts see) scuff them with a scuff pad just to give the powder more to grab to. I have coated chrome without scuffing and had no problems! Just clean it GOOD and coat as you would normal parts.
Should I cure the Lollypop Blue completely before I clear or is there any other methods that anyone has found to produce better results?
I am also considering adding some silver additive to the lollypop blue to give it a metallic look any suggestions? I'm coating some bars for my chopper using the method described above (Harleydad) using the solar flat black powder I'll let ya know how it turns out!
~4bangger "Loud bikes save lives, Let'em breathe" |
| ClearCoat ? | donafams | Powder Coating Questions | 5 | 09-09-2007 07:13 AM |
| Clearcoat question | donafams | Powder Coating Questions | 1 | 08-02-2007 07:17 PM |
| cracked clearcoat | goldmankc | Metal Polishing Questions | 8 | 07-04-2007 10:42 PM |
| clearcoat | mtlplshr | Metal Polishing Questions | 1 | 02-08-2002 08:41 AM |
| Clearcoat | Chopper Doc | Metal Polishing Questions | 1 | 01-27-2002 08:53 PM |
