FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 02-08-2008, 03:34 PM
jeremy_smitty is on a distinguished road
Default Double Coat
How do I apply two coats on the same part? I want to apply a first coat, then bake it, and then take it out of the oven and apply a second coat. The reason for this is because I keep getting runs in my parts because I apply to much powder, but that's the only way I can get into the tight corners due to the farady effect. How long do I bake the first coat before I pull it out of the over and apply the second coat?
Old 02-08-2008, 08:49 PM
uricad's Avatar
uricad is on a distinguished road
Default Re: Double Coat
Try a thinner first coat, do the problem areas first. It takes a lot of powder to make a run. I've found being patient with the powder helps. It may take a while to get the second coat to stick. Many fine dustings seem to work for me. You'll get it.
Old 02-09-2008, 09:05 AM
JTW37's Avatar
Caswell Platinum Member
Another method that has been used for second coats, is to cure it and pull it from the oven and let it get down to around 180 deg and hot flock it. But be careful with hot flocking or you can get to much powder on on it. It starts to flow as you spray.
Otherwise cure the first coat and let it cool and just spray the second coat. Make sure you have a good ground on the part
What gun do you have?
Old 02-13-2008, 12:48 PM
boxerdog99 is an unknown quantity at this point
Has anybody tried to powder coat multiple thin layers to eliminate the orange peel effect? Also, once you have an orange peel effect do you need to reblast an remove first PC layer and do it again?
Old 02-13-2008, 01:47 PM
mikmj's Avatar
mikmj
No I would just sand with 320 and recoat............
Mike
MJM Powder Coating
Old 02-13-2008, 06:53 PM
Harleydad's Avatar
This or wet sand and buff
Old 02-14-2008, 04:49 PM
Have you ever tried using a rouge polishing compound? The reason I ask is because the part has a lot of nicks and crannies to get it all with wet sand and buffing.
Powder Coat Primer with Wet Paint Top Coat? FigureLLC Powder Coating Questions 10 07-02-2008 08:25 AM
double coat irelandmoss Powder Coating Questions 9 01-16-2008 06:35 PM
Anyone ever use a double oven? pcer Oven Building Forum 2 11-27-2007 05:23 PM
double nickel plate Cameratrick Electroplating Questions 5 02-08-2006 08:10 PM
