Old 02-12-2008, 07:32 PM
scoyne is on a distinguished road
Default Blast Cabinet / Powder Dust Removal
I'm acquiring stuff to start to do my own PC and Blasting "Hobby Shop" and will be constructing my own Powder Booth (Only item left).
I have read that you can easily remove the dust from a blast cabinet with a shop vac into a bucket of water.
That being said, My question is this...
Can I use the same setup and tie both the PC Booth and Cabinet to the same line and use the water as the filtering system?
I would pipe it is such a way that I could seal off one when the other is not it use in order to achieve full "sucking" potential.
Can this also be achieved using an old furnace blower motor rather then shop vac? Or will it not be strong enough to pull.
Has anyone done this before?
Let me know your thoughts...
Thanks in advance.
- Sean
dust collector on blast cabinet? shamrox Powder Coating Questions 13 06-05-2008 11:21 PM
Blast cabinet on the way!!! GatorHyde Oven Building Forum 17 01-10-2008 01:53 PM
road to a new blast cabinet krymis Other Metal Finishing Questions 6 09-11-2007 01:15 AM
Incandesent lighing in blast cabinet ottoplex Powder Coating Questions 1 09-10-2006 10:05 PM
building a blast cabinet from scratch 11111111 Powder Coating Questions 10 05-11-2004 04:59 PM
