if youa re doing a candy color over chrome you just clean and coat
if you are doing a solid color like black you have blast or sand the surface so that the powder has something to grab on to. to remove powder I use aircraft paint remover. |
Put your chromed parts in the oven first and run them at around 450 for 15 - 20 min. to see if the chrome will stay put during curring. If it holds up, just spray it and cure. Also, get rid of the glass bead for powder coating. It will cause you nothing but sorrow.
Who says you can't teach an ole dog new tricks? |
Thanks,but as far as getting rid of the glass bead what is better or what do you recomend for a blast media in the cabinet to clean the parts,I thought that glass was better for doing ALUM parts,I was told and also read somewhere that you should not use sand.Any help would be welcomed.
I use the 2 worst medias! sand outside & charcoal slag in my cabinets! silica & arsenic are bad for you !!
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
Silica is definitely out. Glass bead will embed itself in aluminum and out gas bad. I use Coal Slag ( Black Magic or Black Magnum) in my cabinet. Some others use Aluminum Carbide. It's more expensive then slag, but also works well. Can't remember what grit I use, but it works well.
Who says you can't teach an ole dog new tricks? Last edited by JTW37; 03-08-2008 at 10:11 PM. |
| Chrome Powder | jwaldrip | Powder Coating Questions | 8 | 06-20-2007 08:35 PM |
| near chrome powder | fordguy | Powder Coating Questions | 4 | 07-31-2005 08:16 AM |
| Lolly Pop Powder on a Chrome Surface.. Powder is cracking!! | tattoome5150 | Powder Coating Questions | 5 | 06-19-2005 12:46 AM |
| How close to chrome is chrome powder? | remotestartdepot | Powder Coating Questions | 1 | 05-06-2004 03:54 PM |
| Chrome Powder | 04sp500 | Powder Coating Questions | 7 | 08-28-2003 01:19 AM |
