Internal engine parts (rods etc.) require a special coating. Powder won't do it. I have known of guys painting the lifter valley for better oil return. I can't recommend doing it with powder, cause I don't know.
It takes 350 to 400 for powder to cure, but will scorch at about 275 after curred (so I'm told) I did a guy's intake once, and the powder burned at the area that supplies heat for the choke. Needed to block the port off in the head, but he didn't.
Who says you can't teach an ole dog new tricks? |
Why would you want to paint the inside of an engine? What would be the benefit? Possibly smoothing of the airways, but connecting rods and rocker boxes? If it came off it would be a disaster because it would fill up the oil filter.
The color of the paint doesn't matter, white or black or anything else, it all looks black to the infra-red (heat) spectrum unless it's a metallic paint. Bare aluminum reflects heat better than paint. Last edited by sdold; 03-24-2008 at 01:01 AM. |
Painting seals the pores of the casting and speeds up oil flow back to the sump. Most engine builders use GLYPTAL It is a non conductive paint that is great for alot of applications. It is usally brushed on and is available from Caswell. Todd
| Powder coating an engine block questions | caseywan | Powder Coating Questions | 1 | 10-01-2007 08:57 PM |
| Powder Coating an Engine block? | UrineMachine | Powder Coating Questions | 1 | 02-25-2007 09:47 PM |
| powder coating a bike engine | boston_jake01 | Powder Coating Questions | 3 | 10-25-2006 04:55 PM |
| Powder Coating Inside of Rim??????? | chcustom | Powder Coating Questions | 2 | 10-25-2006 09:14 AM |
| powder coating engine parts | spyoung | Powder Coating Questions | 1 | 01-20-2006 09:45 PM |
