well i was originally going to give my stuff to a sandblasted but have read that its not good for quad/bmx parts (thats what im going to be doing most of the time) because it weakens the welds alot after a couple times of being stripped. what other ways are common that the pro's use? i have head something about "burning it off" ?
thanks espo |
Yes you can burn it off or you can use permetex gasket maker (it takes off powdercoat) or I tryed today dupli-color paint stripper in a spray can and it worked really good.
I have some new powder coated brackets that VHT strip fast would not touch. Went to auto paint shop bought aircraft remover it did nothing, but if you read the fine print it says do not use on aircraft. I even baked them at 550 degrees for 1.5 hours they still look the same. I need to purchase a industral type brush on stripper. Any Ideas or brands would help. Thanks, Todd
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
i would just have it blasted i have had no ploblems with the factory welds on my banshee and i have had it coated and blasted twice and it get used hard
its alot of damn work to be shinny
so if i get a powdercoating stripper, but it in a big bin, i put in the part, it will take most of it off and then i can just throw it into my powdercoating oven and let it burn it off?
just want to make sure i have this correct. thanks espo |
| My experience with heat-stripping powdercoat | BottleFed70 | Powder Coating Questions | 2 | 03-03-2008 01:23 AM |
| to those asking about stripping powdercoat | FiReBReTHa | Powder Coating Questions | 0 | 06-13-2007 03:52 AM |
| name this powdercoat | gach | Powder Coating Questions | 4 | 02-17-2006 02:41 PM |
| Stripping powdercoat | Billet | Metal Polishing Questions | 4 | 01-11-2005 11:39 PM |
| Can you powdercoat over powdercoat? | gopedhead | Powder Coating Questions | 1 | 12-14-2003 05:17 PM |
