Buy One Get One Free Powder Coatings
Until July 31st
BUY ONE POUND - GET ONE POUND FREE
(Same color only. Limit 1 Free Pound, Per Color, Per Customer)
- Enter 2 in the quantity field
- Pay the 1 Pound Price for 2 Pounds
Offer Valid On ALL powders, through 7/31, US Customers Only
...if you're doing a candy just clean 'em well & shoot it. if it's a solid tone color give 'em a light blast, light buff or light sanding then clean 'em & shoot 'em.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
Are these twin cam covers. If they are they should be blasted for better adhesion.When I used to do these if there was clear left on after blasting the powder had a hard time sticking. The best way to do these is individually masked all, four parts and outgassed then hotflocked at 200 to minimize outgassing.One thing to watch out for is when you mask off the gasket surface leave about 1/8 inch from the edge tape free so when the covers are together you will have a superior appearance with no rough edges. Another thing to do is to round off the sharp edges to get proper coverage.
Hot flocked means to shoot the part when it is hot or warm to get good coverage. Normal powder will work fine on these covers.The high temp powders are tempermental and if you screw up your first coat you have to strip and start over again. I have learned the hard way that silcone powders are a one coat deal.
true about reg powder on these , blasting them wll get a better adhesion . with a black texture i would not waste time outgasing them i have done many sets and never had a outgasing problem and i never hotflock either
| Rocker Cover. | pootsman55 | Powder Coating Questions | 6 | 03-29-2008 05:58 PM |
| valve covers | jw450r1 | Powder Coating Questions | 5 | 01-20-2008 07:42 AM |
| Harley Evo Rocker Covers | powdersparky | Powder Coating Questions | 3 | 09-28-2007 12:20 PM |
| V-Max Aluminum Side Covers | buzzurd | Powder Coating Questions | 1 | 10-21-2005 07:24 PM |
| valve covers | millerperformance | Powder Coating Questions | 1 | 02-12-2005 01:08 PM |
