Well I've done four pieces now and the last one was a little better. I preheated the piece first and didn't use the liquiguardPC. Just =cleaned with Acetone and then PC. I purchased some Purple Power degrease. I'm now trying the purple degrease before preheat, then I'll clean again with Acetone and then PC. I'll let you know how it comes out. Ben |
1. clean with Acetone 2 clean with purple power degreaser 3. Pre-heat for 10 minutes at 350 degs 4. clean again with Acetone 5. PC 6. bake I noticed that when I use the degreaser I get some areas that have a pronounced whiteness to them. I'm preheating now and will use acetone after the preheat. Last edited by benherr; 04-14-2008 at 11:55 AM. Reason: addition |
I think I finally got it right or at least close. I did the following steps:
1. cleaned the piece with Acetone 2. Cleaned with purple power cleaner/degreaser and rinsed with water. 3. pre-heated piece to around 300 degs for about 10 minutes. 4. let cool down to around 100 degs then cleaned again with Acetone. 5. PC and baked The piece came out with only 2 carters, one very small and one a little bigger. I still have what I'll call like a snake skin effect in the powder coat, which I believe you can see in the photos attached. Can anyone tell me what causes this and how to correct? Am I using too0 much powder or not enough, etc.? thanks, ben |
That is what is called orange peel or OP.It looks like not enough powder.Is that super mirror black you're using.I always get a little OP with it. Try more powder shooting 10 inches from the part. Look in the Caswell can and see how the powder looks(greyish colour)This is about the colour you want on your part before it enters your oven.When your powder goes from black to greyish you're good to go. Put your part in your pre-heated oven at 375 then lower to 350 once in the oven.That part looks thin so it should come up to temp quickly so 15 min. should be sufficient.If failure persists try out the super wet black or the black cat urethane with a clear coat.These two powders always seem to come out super smooth for me.You can also try an epoxy primer before which I use on gas tanks or fenders.
Man, thanks for the info. This has been driving me a little crazy. I'm using the super Wet black on billet aluminum and the stock is 1/2 inch thick. Great info on the pre heating of the oven, which I hadn't been doing. Do you usually put a finish coat over the wet black? Ben |
Powdersparky,
I think you hit the nail on the head. I pre-heated the oven and applied a heavier coat of Powder and this time the piece came out looking really good. a slight orange peel, but nothing like I had earlier and only 1 or 2 carters. See photo below. Thanks for the great info. ben |
using the Caswell hobby gun that sells for $99. the air pressure is set to around 10 Psi. this last piece came out a little better, not so much OP. still getting the feel for the proper amount to apply. this last spray was a little heavier than the previous applications and it does look better. I'm spraying from about 8 inches away from the piece. Any other suggestions would be greatly appreciated and thank you for the reply. Ben Last edited by benherr; 04-15-2008 at 09:23 AM. Reason: additional info |
Len Figure Engineering, LLC |
| Need some help making RED fish hooks | nitro901 | Other Metal Finishing Questions | 2 | 03-27-2008 02:11 AM |
| Helpful Tip : FISH EYES OR WHATEVER | customandsound | Powder Coating Questions | 9 | 02-07-2008 11:16 PM |
| fish eye any way around it ? | coleman5 | Powder Coating Questions | 14 | 12-26-2006 08:53 AM |
| Parts with viewing eyes | seahag | Powder Coating Questions | 13 | 09-24-2006 11:21 AM |
| Fish eye? | Asher | Powder Coating Questions | 3 | 05-21-2003 10:12 AM |
