Old 04-13-2008, 04:44 PM
Murderface is on a distinguished road
Default Film thickness
So I've been having a hard time figuring out just how thick to coat stuff. I'm primarily trying to get good results with xtreme chrome and clear.
I initially did a small drill bit which came out pretty evenly. I think since I was using a low power compressor, it didn't coat it very much. Next, I did an arbitrary piece of pipe on a powerful compressor, which came out pretty orange peely, both after just chrome and after clearcoat.
I did a valve cover yesterday, which I layered on REAL thick. It came out kinda orange peely too, but the orange peely effect was larger/less dense.
I've heard mixed input about this. Some say thicker coats make orange peel, some say thinner do. Is there a happy medium? I'm going to expirement on my own I suppose, but I wanted your input. It seems that very thin coats seem to do better.
I did read the sticky here about chrome. It's pretty vaguely written, but I figured it breaks down to: coat chrome, cure chrome, let it cool, reheat it to 150 deg, coat clear, cure clear. Came out reasonable when I tried it, the clear really dulled the chrome though.
Old 04-13-2008, 04:52 PM
nuttyman's Avatar
nuttyman
Default Re: Film thickness
in my brief 7 years of experience I have found that thicker coats will orange-peel on you. I have had best experience with spraying parts around 2-4 mils.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 04-14-2008, 02:23 PM
mikmj's Avatar
mikmj
To much powder big op too little powder small tight op........
When you spray powder make it look like frost on a window....... not too thick not too thin..........
Mike
MJM Powder Coating
cant remove film to start polishing cantex Metal Polishing Questions 6 01-24-2006 02:03 PM
Copper plating aluminum thin film spigeon Electroplating Questions 0 06-23-2004 09:59 AM
Coating thickness sam4 Powder Coating Questions 0 04-20-2004 09:33 AM
film good or bad MrDmB Electroplating Questions 8 04-11-2004 05:13 PM
color thickness dax89 Anodizing Questions 4 10-31-2003 08:22 PM
