Old 04-16-2008, 11:54 AM
benherr is on a distinguished road
Question How to clean the PC gun???
OK, Call me stupid, but how do you clean the PC gun. Does the end defuser just pull out? there's a screw on the bottom of the gun. does that need to be removed to disassemble it? I don't want ot damage it, so I thought I'd better ask first.
Ben
Old 04-16-2008, 08:42 PM
JTW37's Avatar
Caswell Platinum Member
Default Re: How to clean the PC gun???
The defuser (if this is a Caswell gun or HF), will need to be unscrewed from the shaft. It's long winded, so just keep turning. When that's out, reach down inside the tube with a pair of needle nose pliers and pull out the metal piece. Next pull the plastic screw out of the bottom of the barrel. It should have an O ring on it. After you get all that out/apart, blow out every orifice you find and blow air through the barrel from the front and into the curved tube until no powder comes out. Then give it a good look to make sure there is no powder.
Old 04-17-2008, 07:51 AM
JTW,
Thanks for the info and now another question. After powder coating the piece, should I have the oven up to temp. before placing in oven or does it hurt anything if I place in oven before it reaches the specified temp?
Ben
Old 04-17-2008, 09:10 AM
Harleydad's Avatar
Originally Posted by benherr View Post
JTW,
Ben
Too slow or too quick of a heat up rate can contribute to OP. If I have some heavy material I'll put it in a 450 degree pre heated oven and monitor the part temp until it gets close (350 degrees) to cure temp (400 degrees) then turn down the oven to cure temp.
The opposite with thin walled material. I'll turn the oven on and set it to cure temp (400) and put the part in when the oven reaches 325 - 350.
In both scenarios, start the clock when the part reaches cure temp.
Does that make any sense.
Old 04-17-2008, 11:42 AM
harleydad,
absolutely it makes sense to me. I've been placing the piece in the oven and turning on the heat and waiting for the piece to reach temp and then starting the clock. No wonder I've been getting OP. Most of the items I'm PC are between 3/8th to 1/2 inch in thickness (T-6061 aluminum).
Thanks, I may just get one done that doesn't look like an orange and carters like the moon.
Ben
How clean is your air? Whiplash Powder Coating Questions 13 05-01-2007 12:19 PM
Anyone used LPS Precision Clean? Ikaika Powder Coating Questions 2 03-13-2007 08:04 PM
Clean air chicagorich Powder Coating Questions 2 04-13-2006 02:59 PM
Clean up Mack_Bolan Metal Polishing Questions 4 01-04-2004 04:04 AM
How do I clean off the compound? fatalerror Metal Polishing Questions 5 04-29-2003 08:08 AM
