Buy One Get One Free Powder Coatings
Until July 31st
BUY ONE POUND - GET ONE POUND FREE
(Same color only. Limit 1 Free Pound, Per Color, Per Customer)
- Enter 2 in the quantity field
- Pay the 1 Pound Price for 2 Pounds
Offer Valid On ALL powders, through 7/31, US Customers Only
I have the Caswell "Pro" kit with a 1500 watt lamp for curing. I'm coating suspension parts and the lamp doesn't work very well melting the powder. I end up putting the lamp very close to the part and then moving it around, which takes forever. The max temp I've been able to record was about 220 degrees. Is there any solution other than adding lamps? Is it possible mine is defective?
I think you're right. After spending my weekend moving the lamp around, I'm a bit wiser. However, some parts like my Jag cage in the rear end, aren't going to fit in the oven. I'll have to bite the bullet and use the lamp.
I did get the front crossmember and two spring housings done, and the results are satisfactory. |
If all you can get is 220 your powder is way under cured and will not last.....
Mike MJM Powder Coating |
That's what I figured, as my understanding is that I need to cure at a minimum of 300 deg. F. I'm going to get an old oven, and I may extend it as some of the members here have done. The most difficult part is my front axle, due to its length. I've decided to stop for now until I solve this problem. Fortunately, on old cars, there is always something else I can do.
Thanks for the input. I'm glad I came here to post when I recognized I had a problem. Does anyone have an idea for properly curing the large parts that won't fit into an oven? I'm looking into buildkng a reflector.
Update... found an oven on craigslist for $50... onward, through the fog. Last edited by Travst; 04-28-2008 at 11:01 AM. Reason: added information |
| Building my second oven - slowly | JTW37 | Oven Building Forum | 4 | 02-19-2008 10:00 PM |
| Learning about electrics....slowly! | grommit | Oven Building Forum | 3 | 01-16-2008 09:35 PM |
| IR curing | RRdvark | Powder Coating Questions | 1 | 05-01-2007 05:08 PM |
| curing | zgcfab | Powder Coating Questions | 3 | 05-07-2006 03:08 AM |
| After Curing | getastro | Powder Coating Questions | 4 | 07-09-2003 12:44 AM |
