Hi, I am new here. I am about ready to get my Powder Coating set up soon. Just a hobby size with an electric oven for now
Thanks, Grumple |
Only judging from what I've read...the redline gun isn't the best of quality. I use a Harbor Freight hobby gun, works fine, but I don't have the ability to adjust the voltage...which can come in handy.
If you're just starting out, I would say go with the Caswell adjustable voltage hobby gun. Alot of guys on this forum use it with awesome results and the price wont break your bank. As for the sandblaster...DO NOT USE PLAY SAND!!!!!!!!!!! It can really hurt you. I use aluminum oxide, with awesome results. Glass bead tends to embed itself into some of the softer metals, causing imperfections when baking. You can buy either at your local Harbor Freight for about $25 for 25lbs. Hope that helped a bit, John |
Thanks for the info. Does the aluminum oxide come in different grit sizes? If so, which size for best all around use? I read about black oxide. Is this better or is it all black? We have a Harbor Freight about an hour from here... I know about the sand issue as I read it once on a bag of play sand when I was going to blast some parts with an open air blaster. I prefer to be safe.
Grumple |
Thanks, Grumple |
How does this compare to aluminum oxide?
from my personal experience , aluminum oxide last a bit longer , the black diamond last about 4 cycles . maybe a bit more . i use a pressure blaster in a cabinet and it works great . and leave a heck of an "etch" or the coating to adhere to .
when i was buying aluminum oxide it was like 40.00 for 50lb , the black diamond is like 7.00 a 50lb bag ., kinda a no brainer if you live close to a tractor supply . or go to there website ATI - Black Diamond i think they may sell whole sale but did not try yet |
I get my Black Magnum (Called Black Beauty some places) from Menard's, for just over $5.00. You might want to look into Lowe's, they may have it as well. If none of the names ring any of the store peoples bell, just tell them it's coal slag. Maybe then they will know what you want.
Who says you can't teach an ole dog new tricks? |
