Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: How Do You Powder Coat Over Chrome?
  1. #1
    welterracer is offline Amateur Metal Finisher
    Join Date
    Sep 2007
    Posts
    210
    Default How Do You Powder Coat Over Chrome?
    Hi..
    My name is Brian, and im new to the forum,and I am co-owner of a small Powder coating business.
    I have a customer who wants us to powder coaticon his 20" Chrome wheels which are rust pitted!
    What do i have to do, to insure that the powder coating will stick and look nice?
    Ive heard that the chrome has to be completely removed.. Is this true? and if so how do you get it off?
    Thanks a ton
    Brian
  2. #2
    Harleydad's Avatar
    Harleydad is offline Metal Finishing Guru
    Join Date
    Dec 2006
    Posts
    837
    Default Re: How Do You Powder Coat Over Chrome?
    If it's pitted and rusting it's best to remove it. Take the rims somewhere to get them stripped.
  3. #3
    Join Date
    Sep 2007
    Posts
    210
    What would you use to strip them that wouldnt destroy the aluminum?
    Halfbakedcoatings.com
  4. #4
    Harleydad's Avatar
    Join Date
    Dec 2006
    Posts
    837
    A shop that does chrome or plating may be able to strip them.
  5. #5
    Join Date
    Sep 2007
    Posts
    210
    Couldnt you just sand them down or grind down the pits?
  6. #6
    Harleydad's Avatar
    Join Date
    Dec 2006
    Posts
    837
    If you coat them and there's still rust creeping under that chrome, how long will it be before you're doing them over?
  7. #7
    Join Date
    Sep 2007
    Posts
    210
    Ive done alot of searching o other forums on different sites..
    Some people say you can powder coaticon over chrome with no problems as long as its very clean.. Others say just the opposite.. saying it cant be done and it wont last..
    WHO KNOWS FOR SURE?
  8. #8
    Harleydad's Avatar
    Join Date
    Dec 2006
    Posts
    837
    Quote Originally Posted by welterracer View Post
    WHO KNOWS FOR SURE?
    You can coat over chrome if it's in good shape. If your using transparent/candy colors, clean really, really well, coat and cure. If using a solid color, lightly blast or go over the part with a scotchbrite to aid in adhesion. I usually run chrome parts through an outgas cycle first (450 degrees for an hour). If the chrome bubbles/blisters, it needs to be removed. In your case pitted and rusty, I wouldn't take the chance and would have them stripped. Your coating is only as good as your base.
  9. #9
    bikerchico is offline New User
    Join Date
    Dec 2008
    Posts
    1
    place chome piece in5 gallon bucket and a cup of baking soda. now u need a battery charger . and a stainless rod but any rod will work. attach red lead to chome pease. place rod in bucket be sure the rod does not touch chome peace. attach black lead to rod. this will remove all chorme. check every 4 or 5 hours. the metal will come out looking black. sand blast or clean.I have done this plenty of times.it realy works
  10. #10
    tr4dude's Avatar
    tr4dude is offline New User
    Join Date
    Nov 2007
    Location
    Sunny California
    Posts
    44
    great cheap idea, i will try that out on a set of rusty chrome rims soon!!
    Sonic Powder Coating
    Sonic Coatings@aol.com
Thread Information
Users Browsing this Thread
  1. Replies: 1
    Last Post: 03-10-2008, 04:33 AM
  2. Chrome powder coat or equivalent service??
    By redhotcuda in forum Services Offered/Wanted
    Last Post: 09-07-2007, 11:14 AM
  3. Shiniest Chrome Powder, and do i need to clear coat it?
    By investinwaffles in forum Powder Coating Questions
    Last Post: 07-20-2006, 07:24 PM
  4. chrome powder coat
    By lowgmc94 in forum Powder Coating Questions
    Last Post: 04-21-2005, 01:56 AM
  5. Look of Chrome Powder Coat?
    By rabiddog22 in forum Powder Coating Questions
    Last Post: 05-12-2003, 03:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
