+ Reply to Thread
Results 1 to 2 of 2
Thread: Air compressor
  1. Air compressor
    I am new too powder coating and have been reading about the gun (have not bought one yet). They all talk about using (5-10 psi). Mine question is how much CFM/SCFM does it need? I already have an air compressor and was needing to know if it puts out enough air or am i going to need a bigger one.
    Share with Facebook
  2. Join Date
    Apr 2003
    Posts
    134
    As long as your air compressor is bigger than one of those 12 volt emergency tire inflators, you should be OK. If it has a tank, you're good to go. Very little air volume is required. Regulate the pressure to between 10 and 15 lbs. There is a small adjustment knob on the handle of the gun (right near the air inlet) for making fine adjustments while dusting. I've had my kit for a couple of months, and I really like it.
    Hemi-T
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Tips and Tricks
    By non-stick in forum Powder Coating Questions
    Last Post: 03-15-2010, 11:41 AM
  2. Compressor help
    By mpierich in forum Metal Polishing Questions
    Last Post: 07-13-2005, 10:29 AM
  3. Compressor Amperage
    By edomingox in forum Powder Coating Questions
    Last Post: 04-12-2005, 04:02 PM
  4. Air compressor questions
    By Jay87T in forum Powder Coating Questions
    Last Post: 02-25-2005, 11:47 PM
  5. Air Compressor Recommendation - Silvachrome
    By Therber in forum Other Metal Finishing Questions
    Last Post: 05-25-2003, 06:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
