  #11 (permalink)
Old 05-17-2003, 11:51 PM
regular elements will work for your application. and wiring sounds like you got it. Now the advice will be $7995.00 and you still saved 5 bucks versus the $8000 oven.
  #12 (permalink)
Old 05-18-2003, 11:07 AM
getastro's Avatar
getastro
Default oven
Thanks Dale for all the info. Just drawing plans up now for the oven frame. The info you gave is just what I was looking for. Also the check is in the mail.
P.S. When you hook up your elements to the relay, do you hook up both the red & black wire (for 220V) to thr relay or one to the elements the other to the relay?
  #13 (permalink)
Old 05-18-2003, 11:40 PM
relays vary from type to type. I prefer ones that open all lines. Never tried any other. Mine has both on relay then to element.then next element to previous one and so on.
  #14 (permalink)
Old 05-18-2003, 11:56 PM
getastro's Avatar
getastro
Default oven
Thanks, I guess I have to go out and start to order stuff. Thanks a lot Dale.
  #15 (permalink)
Old 07-26-2003, 02:33 AM
warchild's Avatar
warchild
Default Ovens
If anyone wants a BIG oven you can check out this site. www.equipmentresale.com they have some big used 6ft x 5ft x 6ft ovens for $1,500. some in rough condition. and they have IR ovens up to 14ft long too.
WARCHILD
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
where to buy a real powder coating oven? randygrapes218 Powder Coating Questions 2 08-15-2004 12:50 AM
Powder coating oven suggestion (wiring) tomg552001 Oven Building Forum 1 04-22-2004 02:02 PM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 12:49 PM
powder coating oven tougher finish required d608454 Powder Coating Questions 5 07-27-2003 10:07 PM
