+ Reply to Thread
Results 1 to 4 of 4
Thread: valve cover question
  1. valve cover question
    I have a guy who wants a honda valve cover powdercoated red wrinkle with the raised letters polished. I was wondering if I should: polish - clear - then red wrinkle, or polish - red wrinkle - then clear? I'm not sure what the outcome would be clearing over the wrinkle. I was wanting to clear the polished letters to keep them from oxidizing. I tried searching but didn't find anything about wrinkle & clear. Thanks Jason
    Share with Facebook
  2. Join Date
    Apr 2004
    Posts
    475
    Re: valve cover question
    polish letters then coat the valve cover and then clear everything
    if you are not ussing clear on the valve cover then clear the letters before coating the cover.
    I don't like clear over wrinkles, I like that flat stock look of wrinkles
    Share with Facebook
  3. Join Date
    Nov 2007
    Posts
    85
    Here is how I would do it.
    Polish letters but without any compounds.
    Shoot wrinkle red.
    While wrinkle red is coated and NOT cured clean off the letters with a semi damp foam brush carefully.
    With your mouth blow off excess build up.
    Bake in oven to cure.
    Then go back over and polish letters with compound.
    You can use a semi gloss clear or a lower gloss clear on wrinkles to still keep the semi flat look. If you are not sure how the clear will look like over it shoot some sample panels. Also shoot a test panel polished with the clear by itself no wrinkle to see if it will look good.
    Hope this helps.
    Share with Facebook
  4. Re: valve cover question
    Thanks guys, I appreciate the input.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Serious Help Needed, Polishing aluminum valve cover.
    By m3the01 in forum Metal Polishing Questions
    Last Post: 01-28-2008, 12:57 PM
  2. Valve cover polishing-time and effort
    By grommit in forum Metal Polishing Questions
    Last Post: 12-10-2007, 08:54 PM
  3. Rust inside valve cover, What to do?
    By chromo in forum Powder Coating Questions
    Last Post: 09-01-2007, 02:43 AM
  4. Aluminum Valve Cover Question
    By ptim in forum Metal Polishing Questions
    Last Post: 03-23-2007, 05:32 PM
  5. Lettering on a valve cover???
    By 3000gtvr4 in forum Powder Coating Questions
    Last Post: 12-02-2005, 10:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
