Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 08-12-2008, 06:03 PM
donafams is on a distinguished road
Question Polished Alluminum Rims & High Gloss Mirror Black?
I was told not to use alluminum oxide on rims when using high gloss black, would scotch briting polished alluminum rims be ok when using mirror black?
Old 08-12-2008, 07:07 PM
Harleydad's Avatar
Harleydad will become famous soon enoughHarleydad will become famous soon enough
Default Re: Polished Alluminum Rims & High Gloss Mirror Black?
Are you sure you're not confusing the aluminum oxide with glass beads? Some say glass bead will embed itself in the aluminum, although I've not had a problem. What grit aluminum oxide?
I don't see why the aluminum oxide would be a problem, if you're concerned about it the scothbrite would also be o.k.
Is the whole rim being done in mirror black or are you leaving some portion of it polished?
Old 08-12-2008, 07:10 PM
just the front of the rim, but if i can just scotch brite it, i would rather do that. so it would turn ok ok if i did?
Closed Thread
GSXR midpipe High temp gloss black FiReBReTHa Powder Coating Questions 4 09-10-2007 12:18 PM
High Gloss Powder Coat Help clueless Powder Coating Questions 10 03-28-2007 05:21 PM
high gloss clear boston_jake01 Powder Coating Questions 5 01-23-2007 11:08 PM
Super mirror black or low gloss black? Deecoat Powder Coating Questions 2 03-09-2006 11:24 PM
Super mirror 500+ gloss rated colors customandsound Caswell Please Sell This... 5 11-10-2005 09:20 PM
