Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
  #11 (permalink)
Old 09-21-2008, 09:05 PM
Harleydad's Avatar
Harleydad will become famous soon enoughHarleydad will become famous soon enough
Default Re: Can I touch-up this valve cover or do I have to start over?
Whichever you choose, find a clear close to the gloss level of black your using. You may want to shoot a test panel first to see which you like better.
  #12 (permalink)
Old 09-21-2008, 09:32 PM
x1rider is on a distinguished road
and when you add a clear on top of the flat black "basecoat" do you use the technique described in your first reply?
Is it OK to just leave the flat black coat without a clear or does it compromise the durability too much?
  #13 (permalink)
Old 09-21-2008, 10:23 PM
Harleydad's Avatar
Just apply the clear as a second coat after curing the first coat. You don't have to clear it, although clear does add some durability.
  #14 (permalink)
Old 09-22-2008, 06:09 AM
OK, thank you very much for your help. If you have a gallery with some work you've done on Harleys, I'd appreciate it if you could post a link.
Thanks
  #15 (permalink)
Old 09-22-2008, 08:24 AM
welterracer is an unknown quantity at this point
I used high temp black on a snowmobile exhaust and put two coats on it and had no problem.. i didnt sand it or anything..
A year later and that customer is still working with me and had no complaints..
Halfbakedcoatings.com
  #16 (permalink)
Old 09-22-2008, 08:30 AM
Thanks for your input, maybe I'll try that first before I strip the whole thing. If it doesn't work, I'll restart from scratch.
Would you say I should just maybe sand the edges where the PC meets the raw aluminum to "blend" them and go for a second coat from there?
  #17 (permalink)
Old 09-22-2008, 06:19 PM
Sure.. sand the part first.. and preheat it..
  #18 (permalink)
Old 09-26-2008, 07:07 PM
I am just wondering what you ended up doing..
  #19 (permalink)
Old 09-26-2008, 07:36 PM
I just finished sanding the edges, I'm going to try a touch up first, see if I can get away with it. If it doesn't work, I'll strip the whole thing and start over (tomorrow).
Closed Thread
valve cover question superj Powder Coating Questions 3 06-25-2008 02:01 PM
Serious Help Needed, Polishing aluminum valve cover. m3the01 Metal Polishing Questions 29 01-28-2008 12:57 PM
Rust inside valve cover, What to do? chromo Powder Coating Questions 3 09-01-2007 02:43 AM
Aluminum Valve Cover Question ptim Metal Polishing Questions 44 03-23-2007 05:32 PM
Lettering on a valve cover??? 3000gtvr4 Powder Coating Questions 1 12-02-2005 10:04 AM
