Old 10-06-2008, 11:09 PM
Luck_E's Avatar
Luck_E is on a distinguished road
Post High TEmp Powder
I have an intake that I am doing for a client. The intake has already been throughly cleaned. Can Iron Phosphate be used on the final rinse? What is the length of curing time on this. Does anyone have any input or advise. Thanks.
God Bless!!!
Lucky
3 Nails Powder Coating
Old 10-07-2008, 11:41 AM
Harleydad's Avatar
Default Re: High TEmp Powder
God Bless!!!
Lucky
Is the intake aluminum? If the phosphate is a multi-metal chemistry and contains flourides you can use it on aluminum, otherwise no real benefit.
If you're going to use a high temp powder, I wouldn't phosphate. Clean real well, blast, outgas, clean or blast again, blow off with clean dry air, coat and cure. The length of cure time depends on the cure temp of the powder i.e. the powder cure instructions say 400 - 10 min. That means when the part temp reaches 400 (checked with an I.R. temp gun) start the clock.
High temp powder on HD pipes?? Banditperformance Powder Coating Questions 2 02-13-2008 02:55 PM
Caswell High Temp Powder donafams Powder Coating Questions 3 07-09-2007 03:07 PM
High Temp Ceramic powder lfsracing Powder Coating Questions 7 10-06-2006 12:10 PM
High Temp Powder?? trsick Powder Coating Questions 13 10-11-2004 09:25 PM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 12:20 PM
