Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Old 11-19-2008, 10:55 AM
donafams is on a distinguished road
Question Motorcycle Rims w/Bearings ?
I have a Honda VTX 1800 with cast aluminim rims and want to powder coat without removing the bearings. Is this going to be ok? Im thinking about the heat with the steel bearings and aluminum rim..
Old 11-19-2008, 11:47 AM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Motorcycle Rims w/Bearings ?
i think that's not ok, bc the heat is going to kill the grease in the bearings. i think some others on here have said they've tried it and it smoked badly, and they have to replace the bearings anyway. aftermarket bearings are typically pretty cheap. I paid I think about $20 a pair for my BMW bearings (maybe it was $10), and nothing's cheap on that thing.
Len
Figure Finishing
www.FigureEngineering.com
866-900-4949
Old 11-19-2008, 02:51 PM
Harleydad's Avatar
Harleydad will become famous soon enoughHarleydad will become famous soon enough
I wouldn't do it. There the lube leaking factor and steel and aluminum expand and contract at different rates, they may just fall out as your curing.
Old 11-19-2008, 03:41 PM
FigureLLC's Avatar
the manual for the bmw recommended sticking the rim in the oven to remove them. perfect, i thought. those bad boys still wouldn't budge. had to negotiate em out with a hammer.
Len
Figure Finishing
866-900-4949
Old 11-19-2008, 10:38 PM
CarWiz's Avatar
Yeah, cooking grease in your oven is a no-no. Bearings or not, the oil vapors will fill your oven and ruin a job. And maybe a couple of jobs after that.
Polishing Alum. Rims on Motorcycle RedBaron Metal Polishing Questions 7 01-30-2008 12:40 AM
GOLD PLATING OF LARGE MOTORCYCLE PARTS NEEDED i.e. RIMS, SWINGARM, OTHER PARTS!! REVS Services Offered/Wanted 1 12-28-2007 12:36 PM
Alternator, Bearings? chromo Anodizing Questions 5 07-31-2007 10:31 AM
Motorcycle Rims Need Powder Coating Lt_Dan Powder Coating Questions 6 04-19-2007 11:55 PM
Motorcycle Rims Need Powder Coating Lt_Dan Powder Coating Questions 6 04-17-2007 05:17 PM
Powered by vBulletin® Version 3.8.2
