Aside from the little tantrumI think it's possible that the temp is causing the issue,.... a little. But the more likely reason is a poor ground of the part. Doesn't matter if the gun ground is there and great or not,.... if there's no ground in the electrical box/outlet. Ground the part to true ground. That should help a lot. Then hook the gun's ground to that true ground,.... all will work like a champ.
When I say true ground, I mean true ground... EARTH. Drive a stake in the ground as deep as you can (they sell grounding stakes at Home depot,... they're 8 feet long and a bugger to hammer into the ground. The standard is to get the whole thing except the top into the ground..... That means you can dig a long trench and bury it according to code around here..... or drive it in at an angle or whatever..... leave enough to make a connection to it also),... they sell the clamp for your wire at HD too.
Run a solid core ground wire (10 gage or so if you can find some cheap enough, from the rod outside, through a wall,(yes, you'll want to drill as small of a hole as you can get away with) and seal it on both sides of the wall, (inside and outside). Make a solid copper block and mount it to the wall, or attach a solid wire in a place so you can attach your work to it via a good jumper wire,.... once again I'll recommend some 10 gage, this time, multi-strand wire for this one for flexibility..... Using some kind of clamp you like, attach the wire from the block to your hanging rod or something nearby so that you can use an even smaller wire to attach to the part you're shooting......
Sorry for the long post, but that should get you near your goal of attraction of powder to part.
LinkBack URL
About LinkBacks
