Your uneven second coat problem sounds like a ground issue. Are you replacing hooks between coats? I coat until flow out then an additional few minutes to be sure flow out is complete then when cold to the touch I recoat. For the second coat I replace the hook and check the hole for powder, also I reduce the voltage by 25%.Then cure at normal temp and time as you would a single coat.
LinkBack URL
About LinkBacks
