Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Old 02-12-2009, 09:56 PM
goincrzy's Avatar
goincrzy is on a distinguished road
Default Rims and Clear coat??
I got another questiion for you guys. When someone wants a set of rim done, and there aluminum how do you know if they have a clear coat or not?? Also if they do what are you using to get the clear coat off
Old 02-13-2009, 10:46 AM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Rims and Clear coat??
i haven't done a ton of rims, so i really don't know myself... i think most alloy rims will have a clear. to tell you can put a drop of stripper on them and see what happens. or, since you'll want to outgas them anyway, stick them in the oven at 450-500 before blasting. the clear will turn brown. it should blast off really easy, and now you can see more clearly that you've gotten it all.
Len
Figure Finishing
www.FigureEngineering.com
866-900-4949
Old 02-13-2009, 11:14 AM
Harleydad's Avatar
Harleydad will become famous soon enoughHarleydad will become famous soon enough
Clean a spot on the rim to get the dirt and stuff off. Put a little polishing compound (Mothers) on clean rag and rub the spot you just cleaned. If the rag is black = bare aluminum. If the rag is still clean = it has a clear of some type.
Old 02-13-2009, 12:43 PM
FigureLLC's Avatar
nice. i'll stick that in my bag of tricks.
Len
Figure Finishing
866-900-4949
Old 02-14-2009, 10:05 AM
goincrzy's Avatar
Both of those tips are very good... If you stick the rim in the oven at a high temp the clear coat actually turns brownish? And then you just blast them....Thats a really good idea, that has to make it alot better then trying to use aircraft stripper to get the clear coat off!! Especially in all those tight crevises...... Using the rag and polish is genius!! Thats a good way to see if you even wanna mess around with a set of rims.....I'll have to try both of these tricks.... Thank you...
Clear Coat Luck_E Powder Coating Questions 3 04-26-2008 04:04 AM
Clear coat???? JeffL Powder Coating Questions 5 05-05-2007 03:57 PM
Clear Coating Aluminum Rims sage Powder Coating Questions 2 08-03-2006 10:33 PM
stripping rims of clear mirrorfinish Metal Polishing Questions 2 02-04-2006 02:21 PM
