Results 1 to 3 of 3
Thread: motorcycle gas tank powder coating?
  1. #1
    Join Date
    Oct 2008
    Posts
    13
    Default motorcycle gas tank powder coating?
    My question is simple,
    May i powder coaticon my motorcycle gas tank or am i risking an explosion as the gas vapors still in the tank?
    Thank You
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: motorcycle gas tank powder coating?
    While the auto ignition temperature is between 475 and 495*F, gasoline produces explosive vapors at any temperature above about -45*F. Clicking relays or sparks from a fan could set off vapor. I wouldn't take the chance unless you can thoughly wash/flush the tank and fill with CO2 or Nitogen. (Unpressurized or 0psi)
  3. #3
    JTW37's Avatar
    JTW37 is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Location
    Bristol, In
    Posts
    776
    The way that I have used for several years, is to get you a gasoline engine running (car or garden tractor) and run the exhaust into the tank for around 30 minutes. This will get rid of the gas fumes and make it safe to even weld it if you want. But make sure it gone by smelling it first. It's worked for me for years.
Thread Information
Users Browsing this Thread
  1. powder coating a used motorcycle tank...
    By k2 in forum Powder Coating Questions
    Last Post: 05-26-2008, 05:36 PM
  2. Motorcycle Rims Need Powder Coating
    By Lt_Dan in forum Powder Coating Questions
    Last Post: 04-19-2007, 11:55 PM
  3. Motorcycle Rims Need Powder Coating
    Last Post: 04-17-2007, 05:17 PM
  4. Powder coating motorcycle eng.
    By boston_jake01 in forum Powder Coating Questions
    Last Post: 10-28-2006, 01:12 AM
  5. Coating motorcycle tank and fenders
    By lsw11 in forum Powder Coating Questions
    Last Post: 10-31-2005, 12:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
