Results 1 to 4 of 4
Thread: coating polished wheels ??
  1. #1
    73fbody is offline Platinum Member
    Join Date
    Feb 2009
    Posts
    2
    Default coating polished wheels ??
    New guy here, first post.
    I have the Eastwood kit and have had good results with it but never coated aluminum much less polished. Just bought a new set of polished aluminum wheels and want to coat them, are there any precautions to take?
    I did a search already and see that aside from cleaning them, they should be preheated. Any issues with coating polished aluminum?
    Thanks in advance. Joe
  2. #2
    welterracer is offline Amateur Metal Finisher
    Join Date
    Sep 2007
    Posts
    210
    Default Re: coating polished wheels ??
    Outgass.. clean very well with acitone.. and shoot..
    Halfbakedcoatings.com
  3. #3
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by 73fbody View Post
    If they are new, They are probably coated with some kind of clear already. This must be identified. Cook the new wheel (just one for starters) for an hour or more at, or above, curing temp of the powder you plan on using. I'd go 450, for about an hour to an hour and a half. If the wheel yellos, or turns brownish, It's liquid paint clear. If it doesn't, then it's powder. If it's powder, you can coat over it, but I'd still strip the wheels myself, but that's up to you. The pre-heating would depend on whether the wheels are cast, or biillet. Cast will require Outgassing. Billlet,.... not so much.
    EMAIL scott@scottrodspc.com
  4. #4
    Join Date
    Feb 2009
    Posts
    2
    Thanks for the replies.
    Guess I should have stated these are cast wheels and bare polished with no top coating.
    Guess I will give one a try this weekend and see what happens.
    Thanks again for the advice.
    Joe
Thread Information
Users Browsing this Thread
  1. Clear coat over polished Ali wheels or parts
    By grommit in forum Metal Polishing Questions
    Last Post: 12-18-2007, 10:09 PM
  2. Polished Eagle Wheels
    By puckyou in forum Metal Polishing Questions
    Last Post: 01-16-2006, 09:04 PM
  3. Need help polishing my polished aluminum wheels
    By suparida in forum Metal Polishing Questions
    Last Post: 09-02-2005, 09:08 AM
  4. Spotty Polished Wheels
    By dadszx7 in forum Metal Polishing Questions
    Last Post: 05-21-2003, 11:41 AM
  5. Screwed up polished wheels, HELP
    By PartTimer in forum Metal Polishing Questions
    Last Post: 07-10-2002, 10:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
