+ Reply to Thread
Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: Application equipment question
  1. #11
    Join Date
    Nov 2005
    Posts
    945
    Default Re: Application equipment question
    Quote Originally Posted by rsmarco View Post
    he advised me to get a Nordson Shirko
    i'll bet they're really hard to find... i think he meant Sure Coat. easier to find, but yes, expensive.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
    Share with Facebook
  2. #12
    Join Date
    Dec 2006
    Posts
    760
    One option vs the Nordson if you're going spend that much is a Wagner. Also available here:
    Powder Buy The Pound
    Share with Facebook
  3. #13
    PBTP has a Wagner Set up with a 3 pound fluidizing hopper,controller, pump, hand Hi-Coat C4 Hand gun and all the hose connections for a small investment...I know they also stock parts on the guns so you will have no problem there. For me, I use the King Coat and a Caswell gun, and I am happy with both. The Hopper has changed the way I can shoot metallics and clear's but I will always keep my Caswell as back up.
    Share with Facebook
  4. #14
    Quote Originally Posted by JollyCoat View Post
    can you explain the difference?
    Share with Facebook
  5. #15
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    644
    I thought that too, but I've tried many of times to get a better ground, even to the point of having a bolt through the part pinching a wire to the bare metal to assure the ground and still it gets very spotty attraction at best.
    Worst yet is when I try to do large parts like wrought iron or steel ornamental railings, there is just not enough amperage going through it to may the attraction.
    Other issues with the gun are the fact that it gets filled up with powder inside the actual gun, and yes i've cleaned it out completely and tried it and still no better.
    I actually spoke to a rep at NIC industries and he has tested all the guns on the current market with their powders, and although he advised me to get a Nordson Shirko, they are really tough to find and still way too expensive.
    I've looked at your work though Scottrods, and if you are doing that with the EW Pro gun, then I should really get a second look at this gun from the manufacturer, you do some nice work man
    Thanks on the Compliment. I don't do enough work yet though to be professional grade,.... But thanks.
    I went to Home Depot and bought the 8 foot long grounding rod for electrical installations, and drove it into the ground. I use that ground primarily for my parts. I also hook my gun grounding cable up at times, but usually do not have to to get attraction.
    Recently, I read someone on another forum saying he used his hand to allow the current to bleed from the part, helping to start the attraction and keep back ionization down. I tried it and it works too. You won't get shocked, but you may feel your clothing "suck up" to you a little as it charges you, pretty much, along with the part.
    Ground and Static are tricky. I'd recommend checking out a couple more forums for more info on grounding the part/system for attraction. Eastwood's is good, Powder buy the pound's is good also. Check 'em out.
    I don't think your gun is the problem.
    Share with Facebook
  6. #16
    Quote Originally Posted by FigureLLC View Post
    i looked at the king coat and i would still try the hypersmooth first. less expensive and simpler. i bought one of their 2lb hoppers for $10 to try with our Nordson setup, and it worked great! and even better yet, you can store your powder in the same containter as the hopper lid installs onto. beautifully simple and effective and economical.
    The 2lb hopper is tupperware that you can get at any dollar store...A real hopper feeds air through a membrane using compressed air. I looked up Nordson units and they carry a hopper hand gun as well as a box feeder..which do you have ?
    Share with Facebook
  7. #17
    It's not less expensive, its the same price plus Brian talks you into spending $200.00 for a nozzle that can't even spray metallic's and has a value of $20.00 -been there done that, sent it back !
    Share with Facebook
  8. #18
    Join Date
    Jan 2008
    Posts
    79
    I would go for the King Coat Gun for many reasons, the hopper fluidizes the powder just like in manufacturing. THE PURPOSE OF FLUIDIZATION IS TWOFOLD. FIRST, IT ALLOWS POWDER COATINGS TO EASILY BE TRANSPORTED FROM THE HOPPER TO THE GUN WITH A HIGH DEGREE OF UNIFORMITY AND CONSISTENCY. SECOND, FLUIDIZATION SERVES TO PRECONDITION THE POWDER, BREAKING UP AGGLOMERATIONS, REMOVING ABSORED MOISTURE, AND IMPROVING THE HANDLING AND FLOWABLILTY OF THE MATERIAL. The King Coat Gun easily does multipule coats including metallics with no hidden costs. I also know that many of the hyper smooth guns have been sent back to cc. Interesting, TY aren't you on another forum stating that you have the pony from cc not the hyper smooth?
    Hey Jollycoat would you please show me where I said I had the Hypersmooth 02? He was asking for suggestions on a gun and I was giving him my opinion. Please pay more attention to peoples posts before you try and call them out on a public forum. Thank you.
    "I'm your huckleberry" - Doc Holiday
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." -Benjamin Franklin
    Share with Facebook
  9. #19
    Join Date
    Jan 2008
    Posts
    79
    That is true the two guns are the same price. But as I said before I would love to see a direct link to the $20.00 nozzle. If you are going to bash a company's product please show some evidence to back up your story. Its common courtesy to do so.
    Here are my opinions, if you want a gun with a fluidizing hopper from the factory get the King gun. If you want a easy to operate gun for quick color changes with a "remote cup" style hopper get the hyper smooth. Also you can build a fludizing hopper setup for the Hyper smooth for about $60.00 depending on the material prices where you live. I have even built a fluidizing hopper for my CC Pony Gun.
    Share with Facebook
  10. #20
    Join Date
    Nov 2005
    Posts
    945
    oh, i thought i saw $800 vs $900. my mistake.
    do some research on tribos before bashing a product. they have inherent advantages and limitations by design. why exactly do you think corona guns are so common when they're so sensitive to faraday cages, back ionization, and whatnot?
    Len
    Figure Finishing
    866-900-4949
    Share with Facebook
+ Reply to Thread
Page 2 of 4
Thread Information
Users Browsing this Thread
  1. Which is best for my application??
    By benherr in forum Electroplating Questions
    Last Post: 06-06-2008, 07:20 PM
  2. Beginning equipment question
    By Zam in forum Powder Coating Questions
    Last Post: 12-20-2005, 11:57 PM
  3. Marine application
    By Netnut in forum Powder Coating Questions
    Last Post: 08-09-2005, 03:18 AM
  4. special application
    By sam4 in forum Powder Coating Questions
    Last Post: 03-17-2004, 09:16 AM
  5. Hot powder application?
    By Hemi-T in forum Powder Coating Questions
    Last Post: 12-09-2003, 10:13 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
