yes, it can be done. better question is *should* it be done. for some applications i guess it wouldn't matter, but i think the idea of placing the blower on the exhaust side is that it takes a lot less abuse since the air exhausting from the cyclone is a lot cleaner than what's going in. plus you probably get a lot less air noise with it on the exhaust. i believe to minimize noise, your duct going into the cyclone should straight and at least 4 times the length of the impeller diameter... i think i read that out of a NASA noise reduction manual.
LinkBack URL
About LinkBacks
