You are correct. The screw is an adjustable device and limits air flow. It is also supposed to be removed when the gun is cleaned for a color change etc...There is a mod where you cut the little end tip off and therefore remove any adjustment, but that mod makes the gun spray better. I will see if I can find the link...
G
here ya go:
My Caswell gun Mods
and this:
You are an idiot if you dont try this!
and this:
Wish i would of done this along time ago
That ought to get you off to a great start!![]()
LinkBack URL
About LinkBacks
