  #11 (permalink)
Old 07-22-2003, 03:07 PM
rivermasternc
Send a message via AIM to rivermasternc Send a message via MSN to rivermasternc Send a message via Yahoo to rivermasternc
Tom:
The time/temperature should be OK. Drop the temp a bit if you want to try a longer time. Say 375F for 30 mins. Aluminum is not very tolerant of a lot of thermal processing.
Handle the parts with cotton gloves after blasting. If they need degreasing, do that before blasting. I would skip the "pretreatment solution", particularly as a last step. If you have some grit material embedding in the surface, knock that off gently with some 320 grit 3M wet/dry abrasive paper (use dry). Try to not sand the blast profile down, you just want to knock that embedded grit out. If no embedded grit, do not sand at all.
-Scott
J. Scott Moncrief
Manager-Engineering, R&D
Livingstone Coating Corporation
  #12 (permalink)
Old 07-22-2003, 08:59 PM
Default Tom
Okay first thing, don't waste your time talking to your powder manufacturer for a different formula,as a hobbiest it's not gonna happen.
Next media blasting is a great way to physically clean the surface you just need to remove blasting residue afterwards.For aluminum soapy water works fine with a clean rinse then dry in oven and outgass at same time.
Third you can bring most powder cure temps down to 300-325 and add ten min to time, stay above 300 for the whole process. This lower temp should be your ticket to success. Be sure you have a thermometer in oven for accuracy, don't trust knobs they are usually generally set unless you have an industrial oven.
  #13 (permalink)
Old 07-22-2003, 09:06 PM
tomg552001
Send a message via AIM to tomg552001
Thanks for the info guys. So would say 30 minutes at 350 be good or should i go even lower for a longer period of time? Most of the pieces im powder coating are about the size of the part i mentions before. I do use a in oven thermometer to keep track of temp aswell.
  #14 (permalink)
Old 07-22-2003, 09:39 PM
If the part is still giving you trouble go down to 325. 25degrees makes alot of difference in cure cycle.
  #15 (permalink)
Old 01-06-2004, 10:16 PM
dsacco1013
tOM, i WAS WONDERING WHAT WAS YOU OUTCOME?... Caps lock
Dave
  #16 (permalink)
Old 01-07-2004, 01:37 AM
tomg552001
I found that my best method for curing is to outgas at 375 for 15 minutes, than cure at 410ish. It seems to give me really good results.
  #17 (permalink)
Old 01-07-2004, 02:13 AM
drfjr1976
Here are the steps I use when I do aluminum castings.
#1 Degrease
#2 Media blast with silica sand
#3 Clean with acetone
#4 Dry/outgas in oven at 400 for 20-25 minutes
#5 Let part cool completely than reclean with acetone to remove any thing that may have came to the surface during drying/outgassing
#6 Place in oven once again, this time at 375 for 10 minutes
#7 Remove part and coat before the temp drops below 150 so that it will pull the coating into the pours of the casting.
#8 Cure part at 375 for 25 minutes
#9 Turn off oven and alow to cool very slowly, maybe crack the door slightly.
  #18 (permalink)
Old 01-07-2004, 09:27 AM
non-stick
wow.... this post is a blast from the past,huh? A basic guide ( and the "why" this happens) to this same process can be found in the tips and tricks section as well. Pretty neat to see the old posts revisited once in a while,huh? Shows you how far one has come in a short amount of time with a little help from these boards.
  #19 (permalink)
Old 01-07-2004, 09:58 AM
non-stick
by the way.... Scot (rivermaster)... I havn't seen you post in a long time but by co-incidence see you here today. Funny how things happen like this. Good work on the chipper in the album,bud. Just wanted to say it was nice "seeing" you again.... Russ
  #20 (permalink)
Old 01-07-2004, 10:15 AM
drfjr1976
OOPS! I didn't even look at the dates of the posts. I was wondering why Tom was having this kind of trouble. I was actually kind of shocked.
sand blasting cabinet...relocated to tips n tricks section duke Powder Coating Questions 15 12-30-2007 12:28 PM
Tips and Tricks non-stick Powder Coating Questions 27 11-11-2007 03:01 PM
OUTGAS??? tangnut Powder Coating Questions 1 09-21-2003 01:27 PM
Outgas Signs 04sp500 Powder Coating Questions 2 08-02-2003 02:04 AM
20 Silvachrome tips and tricks polygon Other Metal Finishing Questions 4 06-02-2003 09:29 PM
