Old 07-15-2003, 04:21 AM
brianwilliams5
Default High Temperature Masking Tape
Does anyone know where I can get high temperature masking tape for powder coating? I would like to be able to order it online in single rolls of different widths. Eastwood has it, but it's quite expensive and I was looking for other supplyers that might have it cheaper. Too bad Caswell doesn't carry it or I would buy it from them when I buy my powder coat paints.
Thanks,
Brian Williams
Old 07-15-2003, 03:34 PM
mcaswell's Avatar
Caswell Inc Founder
We are getting some in soon. Watch the web site.
Have A Web Site?
Old 07-15-2003, 10:31 PM
www.shercon.com
1-800-228-3218
These people can help you get what you need at good prices for tape,plugs,hooks, and caps.
Old 07-15-2003, 11:20 PM
brianwilliams5
Thanks for the info. I thnk I'll wait untill Caswell has it on their site so I can get my paint and tape at the same time.
Thanks,
Brian Williams
Old 07-16-2003, 01:41 AM
04sp500
Try www.columbiacoatings.com. They have 1/2", 3/4", 1", and 2" wide high temp masking tape. It is in 72 yard roles.
Old 07-22-2003, 01:10 PM
rivermasternc
Send a message via AIM to rivermasternc Send a message via MSN to rivermasternc Send a message via Yahoo to rivermasternc
Woven fabric electrical tape works. You may get some adhesive transfer that will need to be wiped off. Demasking prior to curing works well in some applications. You can use traditional masking tape for that.
-Scott
J. Scott Moncrief
Manager-Engineering, R&D
Livingstone Coating Corporation
Old 07-22-2003, 10:58 PM
Hemi-T's Avatar
Hemi-T
I tried that, and it worked well for me. Regular good quality 3M masking tape will come off clean and easy when you want it to. I also left a couple of small pieces on (by mistake), and they survived just fine.
Hemi-T
  #8 (permalink)
Old 07-23-2003, 09:54 PM
Wkillgs
I often use aluminum foil for masking... It may not give as nice an edge as tape, but it works well for 90% of my parts. You can even roll it up into a ball and use it instead of a plug.
Also used some green mylar tape....mfd by 3M, got mine from work.
  #9 (permalink)
Old 07-24-2003, 08:51 AM
rivermasternc
Default Aluminum Foil Masking
We often use aluminum foil to mask large areas. We use tape for the parting edges and to hold the foil in place. Much quicker and less expensive than trying to mask a larger area with all tape.
There are aluminum foil tapes too, but typically expensive and bad about adhesive transfer to the product if run through the cure cycle.
-Scott
J. Scott Moncrief
High Temperature Powder Coats vector Powder Coating Questions 2 12-11-2004 05:18 AM
high temp tape randygrapes218 Powder Coating Questions 3 07-29-2004 08:57 PM
Tape for Masking johnny933 Powder Coating Questions 2 05-11-2004 03:12 AM
Powder Coating Masking Tape Now Available mcaswell Powder Coating Questions 0 08-21-2003 02:13 PM
Looking for masking tape recomendations. chcarver Metal Polishing Questions 0 03-06-2003 02:51 PM
