Results 1 to 4 of 4
Thread: what happens if powder is too thick?
  1. #1
    defed is offline Amateur Metal Finisher
    Join Date
    Mar 2006
    Posts
    185
    Default what happens if powder is too thick?
    i just got a new PC gun, the one that is supposed to be able to do 10 coats, cold. so while i was redoing some parts that my old gun messed up, i decided to see if it would really do that many coats.
    i had a wrench that had 1 coat of red. we redid 4 batches of satin black parts where i coated the wrench each time. then we had 2 batches of red, repeating the process on the wrench. so now it has 7 coats of powder on it.
    it looks great. there is so much powder on it that the writing on the wrench is practically filled in. i dropped it on the floor and a chip came off the edge of the box end. so i hit it on the table (edge on edge) a few times and another big chip came out, down to the metal. i can see where the powder dented before it failed. if i hit it on a flat face, no problem, just dents it a bit. the coating is hard, can't scratch it very easily. if i pick at the edge of the chip w/ my fingernail, i can't peel it back any more.
    my question is, w/ that many coats, does the coating become easier to chip since it is so thick? or possibly due to so many bake cycles on the inner coats it chips easier?
  2. #2
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    Default Re: what happens if powder is too thick?
    Quote Originally Posted by defed View Post
    you got it. the thinner, the stronger.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  3. #3
    ty1854 Guest
    Just don't go to the other extreme and get it to thin or you will get orange peel. Just coat the part until it is opaque then back the gun away from the part go back over the part with a dusting of powder. Then check for light spots with a LED light. If you can see the substrate through the powder with the light you need to apply more powder to that area. After you do this for awhile you will just know what the proper thickness looks like.
  4. #4
    Join Date
    Mar 2006
    Posts
    185
    thanks guys.
    Doc, you know which gun i got ....i just had to see how many cold coats i could do! normally, i wouldn't have 7 coats on a part! just surprised me at how hard the finish was, yet so brittle, so i figured it was because it was so thick.
Thread Information
Users Browsing this Thread
  1. How thick should i go? + Why 6 Amps CD?
    By gav6280 in forum Anodizing Questions
    Last Post: 12-10-2008, 10:55 PM
  2. Powder Not Thick Enough
    By osmondmark in forum Powder Coating Questions
    Last Post: 03-28-2008, 07:20 PM
  3. thick coatings
    By mh in forum Anodizing Questions
    Last Post: 09-09-2006, 11:06 PM
  4. Problems with thick metal
    By chromeitout in forum Powder Coating Questions
    Last Post: 05-30-2006, 03:59 PM
  5. How thick is a mil?
    By etyrrany in forum Powder Coating Questions
    Last Post: 11-26-2003, 01:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
