Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > RC Model Building
RC Model Building A forum for discussing all aspects of building RC Models, including NASCAR, submarines and the GATO complete model supplied by Caswell Inc.
Old 10-17-2007, 07:38 AM
Slats is on a distinguished road
Default Camera Mods
Hi guys,
just discovered this great forum.
I should have my re-tooled Collins Class sail in a few weeks from Defence Models and Graphics, and I am planning on installing the camera system in the sail.
I will need to reduce the size of the Camera WTC that I bought, and plan to link power wires from the camera WTC to inside my main WTC. I am also thinking I could replace the Voltage reg for the camera and replace it with another one in the main WTC and run the camera off the main drive battery via a new Voltage reg. So long as I have 5 volts going to the camera from the voltage reg - will I be ok?
Thanks
John
Old 10-17-2007, 10:57 PM
Merriman's Avatar
Sub Building Guru
Merriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud of
Default Re: Camera Mods
Originally Posted by Slats View Post
Hi guys,
Thanks
John
So ... you need a WTC for just the camera with the ability to pass a set of power wires from that WTC (in the sail) to the main WTC (in the hull)?
E-mail me.
David,
Old 10-20-2007, 09:13 AM
David, will e-mail you when I get the Sail back.
Thanks
John
John Slater
Sydney Australia
(You wouldn't steal someone's wallet, so don't steal their livelihood. Please Consider this before you buy "cheap" pirated / copied products.)
Old 10-20-2007, 01:23 PM
Merriman's Avatar
Sub Building Guru
Hi guys,
Thanks
John
John,
You nasty down-under type, you!
Just cut out the middle-man -- the dedicated camera voltage regulator you mentioned -- and run power leads to an unused servo port on the side of the receiver. That will put 4.8 Volts into your camera-transmitter. Done! No mess, no fuss.
However, the camera-transmitter represents an additional 100 mili Ampere's load on the BEC (fancy name for 'voltage regulator', usually housed within the ESC), so perform a load test of the entire package (Ampere meter in series with one of the BEC leads -- the red or black wire within the ESC harness that plugs into servo port #3 of the receiver), and operate all the servos during the test.
If total current draw is less than 1.5 Ampere's, you're good to go. But, if 1.5 or more Ampere's are indicated you are putting the power supply at risk of burn-out and you'll be compelled to use a dedicated voltage regulator to drive the camera-transmitter system.
Does any of this **** make sense? I'm tired ... Caswell works me too hard!
David,
Old 10-21-2007, 11:12 PM
makes perfect sense mate.
Thanks I will e-mail you re smaller WTC for camera when the sail arrives
Thanks
john
John Slater
Sydney Australia
Old 10-21-2007, 11:51 PM
Merriman's Avatar
Sub Building Guru
Thanks
john
OK, sounds good, John. Keep in mind that the short cylinder is the same diameter as the unit you have in hand, but only about two-inches long!
David,
My Caswell gun Mods Banditperformance Powder Coating Questions 39 04-24-2008 07:05 PM
BTU Calculator pickleboy Oven Building Forum 2 04-21-2008 11:33 PM
web camera 11111111 Powder Coating Questions 18 11-17-2004 09:35 PM
Powered by vBulletin® Version 3.7.0
