Results 1 to 7 of 7
Thread: Wanted: Tap for 7/8-20 heli-coil
  1. #1
    MrPontiac is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Posts
    296
    Default Wanted: Tap for 7/8-20 heli-coil
    Please if anybody has one for sale let me know.rbudney@comcast.net
  2. #2
    lcaswell's Avatar
    lcaswell is offline Caswell Inc President
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    643
    Default Re: Wanted: Tap for 7/8-20 heli-coil
    Lance Caswell
  3. #3
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    You'll need an STI (Standard Threaded Insert) tap. These are different than standard taps as the actual cut size is larger than normal to accept the insert. (As is the tap-drill size.) The inside thread of insert would then be the called size. Good luck on finding that size though. What's it for? Are you sure it's not metric 22x1.25mm? Even that's not standard.
    Note: The tap will be stamped "STI". If it isn't, it's not for inserts.
  4. #4
    Join Date
    Aug 2006
    Posts
    296
    Just for a project im working on, funny, i can buy the inserts but i cannot just buy the tap& drill to install them unless i buy a complete kit with drill bit and reamer!! Cannot afford all that. I cannot even aquire info on what size i need!
  5. #5
    Join Date
    Aug 2006
    Posts
    296
    Tryed a 56/64 drill bit and installed the heli coil and it was to loose but im close to the size.
  6. #6
    Join Date
    Aug 2006
    Posts
    296
    ok, seems like the 55/64 drill bit is a little to big so im moving down to a 29/32,s, heli coil go,s in but the fitting is just a tad loose!! Im gaining on it.Now i am using a 1 inch 20 tap but i think it will work but afraid its not exactly right.
  7. #7
    Join Date
    Aug 2006
    Posts
    296
    Had a tap made out of california, workd perfect, Im being told to drill carb. body out to 57/64 so far so good!! 128.00$ for the tap!! ouch!!
Thread Information
Users Browsing this Thread
  1. Will hot plate coil work for small oven?
    By UMR_Engnr in forum Oven Building Forum
    Last Post: 01-17-2010, 03:16 PM
  2. JLD612 us w/ a 220v coil
    By TurboRoadster in forum Oven Building Forum
    Last Post: 01-07-2010, 06:43 PM
  3. Powder Coating Coil Springs?
    By donafams in forum Powder Coating Questions
    Last Post: 08-01-2007, 08:47 AM
  4. Contactor with 220 v coil?
    By mtumbleson in forum Oven Building Forum
    Last Post: 04-15-2007, 09:56 PM
  5. Pricing on coil springs
    By callmej75 in forum Powder Coating Questions
    Last Post: 04-17-2006, 09:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
