| Services Offered/Wanted Do you have plating, polishing or powder coating services to sell? Do you have parts that need a new finish, but don't want to DIY? Post your requests here. |
I have a set of wrestling belt plates that I would like to have plated. They are made of cast zinc and I need them gold plated. I am in North Carolina and if you can do the job please contact me at keithkeever@charter.net
I just joined Caswell and didn't notice a reply to your post. So even though it's been awhile since u posted... I hope this helps. You cannot plate over zinc. It must be removed by soaking the part in a mixture of 50% muriatic acid and water. Soak until all the zinc has been dissolved and proceed as if plating raw steel. Since your piece is ALL zinc, it cannot be plated.
It can be plated if you first plate with our Flash Copper solution, which works as effectively as cyanide based copper plates, without the dangerous chemicals. Flash Copper plates very well over zinc.
You can then plate with nickel, then gold.
Fred Luhn Goldies Gold Plating Service New York http://www.goldiesplating.com 718-529-6655 Voice/Fax |
You're welcome
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 09:55 PM |
| Plating and high heat | chromo | Electroplating Questions | 1 | 01-29-2003 01:15 AM |
| plating and size power? | chromo | Electroplating Questions | 7 | 01-18-2003 02:52 AM |
| Electroless Krome plating Q's | chcarver | Electroplating Questions | 1 | 10-10-2002 10:00 PM |
