I will be using a 6 amp car charger as my power supply for your 5 gallon kit. How will this limit the maximun SA of my items? Also what are the symptoms of insufficient current? If I do have theses sypmtoms can I fix this buy running my current battery charger with another one in a parallel configuration? So lets say a 6 amp and a 8 amp charger in parrellel should give me about 14 amps? Correct?
Power Supply
What's a grounded load? An anodization setup is a good example.
Don't believe me? hook up a power resistor across the charger outputs and measure it. I did.
