Hi,
I just tried out my 3.5 gal anodizing kit for the first time. Mostly, I'm pretty happy with the kit. There are two things that I have concerns about.
1. The 100W heaters that came with the kit.
For the dye tank, the instructions say to use one heater to bring the temperature to 60?C/140?F. With one heater, on for approximately 30 minutes, the tank temperature rose from 20?C to 25?C. Upon adding the second heater for another 20 minutes, the tank temperature rose to just below 30?C. Not hot enough.
Also, the dials on the heaters have no markings. I'm not even sure if they are set properly. Is counter-clockwise hotter? From all the way clockwise, what is the typical amount of turns required to reach 60?C?
Or, do I simply need to wait longer?
2. Heating the sealing bath.
I bought a 1200W hot-plate from Canadian Tire. On high for 30 minutes, the temperature rose to 60?C. Obviously not high enough to make water boil. My tank is 7.5L/1 gal. I'm guessing that my my hot plate is underpowered for the job. What do other people out there use? What kind of rating?
In the end, I just put the pot on the kitchen stove. I don't want to do this again--I'm afraid that I might spill something in the kitchen.
Thanks in advance,
Chris
Thanks in advance,
Chris
